This page provides information on what hardware and operating systems are required for Chaos Envision to work properly.
Technical Requirements
Processor
Intel 64, AMD64 or compatible processor with AVX2 support
RAM
Minimum of 8 GB of GPU VRAM. It is recommended to have system RAM at least twice the size of GPU VRAM.
Operating systemMicrosoft® Windows® 10 with Update 2004 (version 10.0.19041) or newer
LicensingEnvision license with License Server 6.2.0 or newer
GPU Acceleration
DXR compatible NVIDIA® or AMD or Intel discrete GPU
For NVIDIA GPUs: RTX series or newer, required driver 515 or newer in WDDM mode, recommended driver 537.13 or newer
For AMD GPUs: RX 6000 series or newer (experimental)
For Intel GPUs: Intel Arc Alchemist or newer (experimental)
Supported Platforms
Chaos Envision works with .vrscene files exported from Enscape, V-Ray, and Corona.
PlatformsEnscapeV-RayCorona
VersionEnscape 4.2 & laterV-Ray Next & laterCorona 12 & later
Support(tick)(tick)(tick)
We recommend using Enscape, V-Ray 5 and later, or Corona 12 and later for the ultimate experience.
If you are not using any of the above-mentioned Chaos products, you can still export .vrscene files from some 3D modelling applications via the free Chaos Bridge compatibility plugin. It is an independent .vrscene file exporter available for SketchUp and Rhino. More details can be found here.
A free .vrscene exporter is also available in Revit as part of the V-Ray toolbar. It does not require a license but requires a V-Ray installation. The exporter is available in V-Ray 7 for Revit, update 1.
Updating Drivers
If you need an updated of your NVIDIA drivers, follow the video instructions.
