3DS MAX SKETCH UP MAYA RHINO CLOUD REVIT CINEMA 4D HOUDINI  MODO NUKE KATANA UNREAL BLENDER STANDALONE PHOENIX PDPLAYER
This page shows where to find the Chaos Group product version.
Page Contents ×
V-Ray for 3ds Max
 Your V-Ray for 3ds Max version can be found in the Render Settings menu, under the Settings > About V-Ray rollout.
V-Ray for SketchUp
Your V-Ray for SketchUp version can be found under the Extensions > V-Ray > Help > About menu.
V-Ray for Maya
Your V-Ray for Maya version can be found under the V-Ray > About V-Ray toolbar menu.
V-Ray for Rhino
 Your V-Ray for Rhino version can be found under the V-Ray > Help > About V-Ray menu.
Chaos Cloud
Use the command “version” to display your Chaos Cloud version.
 version
V-Ray for Revit
Your V-Ray for Revit version can be found under the V-Ray > Help > About menu.
V-Ray for Cinema 4D
Your V-Ray for Cinema 4D version can be found under the V-Ray> Help> About.
V-Ray for Houdini
 When V-Ray for Houdini is launched, its version is printed in the Houdini Console.
V-Ray for Modo
Your V-Ray for Modo version can be found under the V-Ray > Open Event Log menu
V-Ray for Nuke
 Your V-Ray for Nuke version can be found in the Nuke Console window.
V-Ray for Katana
Your V-Ray for Katana version can be found in the Render Log window.
V-Ray for Unreal
Your V-Ray for Unreal version can be found under Edit > Plugins > Chaos Software.
V-Ray for Blender
 Your V-Ray for Blender version can be found under File > User Preferences > Add-ons.
V-Ray Standalone / Application SDK
 Use the command “-version” to display your V-Ray Standalone version.
 version
PhoenixFD for 3ds Max
 Phoenix for 3ds Max version can be found in 3ds Max Command Panel > Modify > Simulation rollout > About.
PhoenixFD simulator must be selected.
Phoenix for Maya
Phoenix for Maya version can be found in Maya > Phoenix FD menu > About Phoenix FD.
Pdplayer
 Pdplayer version can be found in the Pdplayer startup window.
