Scene provided by Evermotion
Official Release
Date - October 13, 2022
Modified
Environment
  • Implemented a default Vantage sun so Physical Sun and Sky option is available in the Environment mode drop-down
UX/UI
Path resolver
  • Improved path resolver now searches every subfolder next to the imported file, for assets.
Motion blur
  • Reduced artifacts from motion blur
Denoiser
  • Improved Vantage denoiser result in refraction and flickering object edges.
  • Improved refraction quality when switching between Vantage and NVidia AI in Combined denoiser mode.
  • Improved reflection detail with NVidia AI denoiser.
Auto-exposure
  •  Improved auto-exposure that accumulate samples in dark areas (single GPU only).
Fixes
Rendering
  • Visual popping of textures with "Dynamic textures" option enabled.
  • Wrong blending of the sun disk with the ground albedo.
  • Wrong alignment of the sky texture's horizon line .
  • Temporal denoiser and postprocessing passes breaking with dynamic textures.
  • Reduce flickering being used when disabled in High quality rendering.
Auto-exposure
  • Crash when starting an offline render with "Auto exposure" enabled on systems with 2 GPUs.
Command line
  • Crash when rendering with -denoiser=0.
  • Hang when the Live Link drops during a sequence rendering.
  • Random abort while rendering sequence using "Render animation using Chaos Vantage".
  • Live Link in 3ds Max doesn't start with the first click on the Start/Stop button.
  • Distributed rendering in 3ds Max to always deactivate when the Live Link stop button is pressed.
Motion blur
  • Not applying to moving objects when using "Render animation using Chaos Vantage".
  • Not rendering in "Render animation using Chaos Vantage" Maxscript.
Import/Load
  • Errors caused by loading empty string texture filenames.
  • Scene animation range one frame shorter when loading .vantage file.
UX/UI
  • UI bug when switching between 'Focal length' and 'Field of view'.
  • Transform manipulation and snapping windows not being disabled in Live Link.
  • Inconsistent spinner value changes on secondary monitor .
  • Wrong rotation range for transform type-ins.
  • Chaos Vantage starting at invalid coordinates when monitor layout changes between sessions .
Render elements
  • Missing velocity in EXR.
  • Alpha getting lost in EXR when motion blur is enabled.
