©Arterra Interactive
Search
Official Release
Date - January 25, 2023
New features
Textures
  • Support for for repeat/offset u/v for 2D Placement texture from Maya when used in bump.
Modified
Rendering
Fixes
Import/Load
  • Crash when importing/loading with animated proxy containing hair geometry.
Texture
  • Crash with EXR file loaded as a V-Ray Normal map in Bump slot material.
  • Texture blurriness when W coordinate is different than 0.
Lights
  • New Default Vantage sun being created each time a non-vrscene is appended.
  • Light intensity to accept only positive values.
Auto-exposure
  • Difference in image brightness when using Auto-exposure and different rendering resolutions.
  • Visual artifacts with fog and Auto-Exposure.
UX/UI
  • Restoring of maximized main window.
  • Active pixels overlay not showing active pixels.
  • Stereo Spherical and Stereo Cube camera types not updating correctly render resolution based on aspect ratio.
Command line
  • Command line rendering with video output file generates separate files.
Rendering
  • Camera types not taken into account, when using sequence rendering.
Batch rendering
  • Wrong FOV for cameras of the render Queue.
  • Render animation with Chaos Vantage, from 3Ds Max, doesn't start rendering when a Live link connection is not established.
