Assets provided by Evermotion
Official Release
Date - October 24, 2024
New Features
Material
Clipper
Water surface
Virtual Reality
Camera
UI/UX
  • Added import camera, light and material buttons in Camera, Lights and Materials tab respectively.
Clay mode
Texture
  • Support for PhoenixFDOcean texture.
  • Support for V-Ray Water Texture in Maya, SketchUp, Rhino and Revit.
Chaos Cosmos
  • Support for Cosmos multi-asset selection and import.
Multi GPU
  • Added support for Light Cache on multiple GPUs.
Modified
Material
  • Improved Thin-walled - now it works with SSS translucency mode of V-Ray material.
UI/UX
  • Added object type specifier icons to the Scene outliner.
  • Improved opacity - now clip opacity is enabled by default.
  • Improved soft ranges of UI sliders to be readjusting based on type-in input.
  • Improved the text elision in dropdown boxes.
  • Improved the Home Screen - now it doesn't appear when starting a Live Link session and Vantage is not started.
Tools
  • Improved Move Pivot tool to respect the local/world coordinate space toggle.
Scene states
  • Improved the interpolation of scene states when NONE is used - now NONE is skipped when calculating state interpolation.
Clouds
  • Improved the rendering of clouds when using DLSS, at large upscale ratios the flickering is greatly reduced.
Color corrections
  • Improved the Bloom post effect to better match round shapes.
Multi GPU
  • Improved the multi-GPU offline rendering speed with compositing elements.
Fixes
Virtual Reality
  • Washed out colors on Virtual Reality headsets.
Chaos Cosmos
  • Blur on newer Cosmos animated assets.
UI/UX
  • Wrong undo action when renaming objects in the Scene outliner.
  • Long Home Screen delay when loading DropBox scene thumbnails.
  • Inconsistency in display selection on startup.
Rendering
  • Black pixels caused by weighted firefly filter in rare cases.
Importing
  • Mismatch of timing of deformed and animated transformed objects when .vrscene is imported instead of opened.
  • Wrong loading of Anima textures at arbitrary frames when .vrscene is imported instead of opened.
Render devices
  • Device selection regression introduced in 2.5.2.
Importing
  • Wrong point light intensity when using Lumens or Watts.
