This page provides information about the Export and send as .vrscene to Chaos Vantage tools.
The Export and send the current scene as static .vrscene to Chaos Vantage and Export and send the current animation range as a .vrscene to Chaos Vantage tools help you send your 3ds Max scenes and animations to Chaos Vantage with a click of a button.
Installation
The installation of the tool comes with the installation of V-Ray 5 for 3ds Max, update 1 and later.
UI Path
To access the tool, in 3ds Max go to ||Vantage toolbar|| > Export and send the current scene as static .vrscene to Chaos Vantage (
If the button is not visible, press and hold the Export and send the current animation range as a .vrscene to Chaos Vantage( ) button to open the dropdown menu.
To access the tool, in 3ds Max go to ||Vantage toolbar|| > Export and send the current animation range as a .vrscene to Chaos Vantage (
If the button is not visible, press and hold the Export and send the current scene as static .vrscene to Chaos Vantage ( ) button to open the dropdown menu.
Usage
To use the tool, just click the Export and send the current scene as static .vrscene to Chaos Vantage ( )or Export and send the current animation range as a .vrscene to Chaos Vantage ( ) button. The tool automatically:
- Detects if you are using V-Ray 5 GPU as a renderer and asks if you would like to switch to it.
- Stops IPR or Live Link session currently running.
- Starts Chaos Vantage if it is not already running.
- Еxports the scene in a .vrscene file in the .max project location with the name of the .max file.
- Opens the scene in Chaos Vantage.
