- Phoenix Simulator → Volumetric Heat Haze and Isosurface Render Modes are currently not supported with V-Ray GPU and V-Ray GPU IPR.
- Phoenix Particle Shader rendering is not supported with V-Ray Next GPU and V-Ray Next GPU IPR.
- Phoenix Particle Shader → Points and Cellular Render Modes are not supported with V-Ray 5 GPU and V-Ray 5 GPU IPR.
- Phoenix Particle Shader → Cellular Render Mode is currently not supported with V-Ray 6 GPU and V-Ray 6 GPU IPR.
List of the Supported V-Ray features
Chaos Phoenix 5.10 Official Release | V-Ray Next CPU | V-Ray Next GPU | V-Ray Next CPU IPR | V-Ray Next GPU IPR | V-Ray 5, update 2.2 CPU | V-Ray 5, update 2.2 GPU | V-Ray 5, update 2.2 CPU IPR | V-Ray 5, update 2.2 GPU IPR | V-Ray 6 CPU | V-Ray 6 GPU | V-Ray 6 CPU IPR | V-Ray 6 GPU IPR | ||
Simulators, Volumetric Render Mode | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||
Phoenix Simulator, Volumetric Geometry/Volumetric Heat Haze/Isosurface Render Mode | ✓ | ✓ Volumetric Heat Haze and Isosurface are not supported. | ✓ | ✓ Volumetric Heat Haze and Isosurface are not supported. | ✓ | ✓ Volumetric Heat Haze and Isosurface are not supported. | ✓ | ✓ Volumetric Heat Haze and Isosurface are not supported. | ✓ | ✓ Volumetric Heat Haze and Isosurface are not supported yet. | ✓ | ✓ Volumetric Heat Haze and Isosurface are not supported yet. | ||
Phoenix Simulator, Mesh/Ocean Mesh/Cap Mesh Render Mode | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ✓ | ||
✓ | ✗ Fog Mode is supported. | ✓ | ✗ Fog Mode is supported. | ✓ | ✓ Points and Cellular Modes are not supported. | ✓ | ✓ Points and Cellular Modes are not supported. | ✓ | ✓ Cellular Mode is not supported yet. | ✓ | ✓ Cellular Mode is not supported yet. | |||
Particle Shader, Render as Geometry | ✓ | ✗ | ✓ | ✗ Fog Mode is supported. | ✓ | ✓ Points and Cellular Modes are not supported. | ✓ | ✓ Points and Cellular Modes are not supported. | ✓ | ✓ Cellular Mode is not supported yet. | ✓ | ✓ Cellular Mode is not supported yet. |
