This page contains information about the V-Ray TexUserInteger node.
The V-Ray User Integer texture allows the user to read and return a single integer value from the User Attributes of the currently shaded object as a result. This can be useful if the same material or texture is applied to several objects in the scene, but you want to control some of its properties with User-Defined properties.
Attribute – Specifies the name of the user attribute that is looked up and returned from this utility node.
Default Value – Specifies the value to return if the user attribute is not found on the shaded object.
Attribute Priority – Switches between the User Attribute and Map Channel options.
