© Bertrand Benoit
Search
Page Contents ×
Official Release
Date – December, 2019
New Features
 Texture
  • Support for Color Corrections in Unreal texture asset editor
    • Brightness
    • Brightness Curve
    • Vibrance
    • Saturation
    • RGBCurve
    • Hue
 UI
  • Added shortcut from V-Ray drop-down menu to in Project settings (info)
  • OptiX render mode (Experimental) in V-Ray Settings tab (info)
  • Dedicated button and dialogue window to save .vrscene file
V-Bake
  •  Support for generating low quality(mobile) lightmaps when lightbaking
Modified Features
V-Ray
  • Improved speed when using Unreal materials in render and lightbake
UI
  • Moved VRay CUDA GPU Device Selection to V-Ray category in Project Settings (info)
.vrscene Import
  • Better .vrscene import progress reporting and monitoring
Bug Fixes
.vrscene Import
  • Crash when importing meshes without normal data
V-Ray
  • Bugs with Normal map input producing incorrect shading
  • "Affects World" property in Unreal lights not updating in IPR
  • Bug with Dome light texture rotation in interactive does not update properly
  • Crash when switching levels while rendering using VRayPhysicalCamera
  • Bug "Use Custom Start Frame" option in Sequencer not exporting properly
  • Exposure not exporting correctly in Sequencer animation when using "3d Max Compatible" in VRayPhysicalCamera
  • Exception in CORE when network error occurs and bitmaps fail to load
  • Directional light renders black with certain color values
  • V-Ray material thumbnail preview mesh might randomly disappear
