© Bertrand Benoit
Release Notes for V-Ray 5 for Unreal, update 1
New Features
Unreal Engine
  • Support for Unreal Engine 4.27
Geometry
  • Initial support for Skeletal Meshes
Render element
  • Implemented Light Mix render element and LightMix Source in VFB
Modified Features
Performance
  • Optimized Interactive rendering performance and responsiveness
Fixes
Installer
  • Bug with auto detection the Unreal Engine's installation directory
Official Release
Date – August, 2021
New Features
V-Ray
  • Updated V-Ray core to version 5.10.03
  • Blue Noise Sampling
  • Initial Out of core support (only V-Ray proxy geometry)
  • Improved Trace depth for reflection and refraction rays
New VFB
  • New implementation of VFB with integrated Layers compositing
Denoiser
  • Implemented Intel® Open Image Denoise
Geometry
  • Support for geometry pivot offset
Materials
  • Support for Coat layer in VRayMtl
Export .vrscene
  • Added export only selected nodes to .vrscene
Modified Features
V-Ray Bake
  • Implemented Custom preset that takes settings from V-Ray Settings tab
Installer
  • Updated Installer
License Server
  • Updated Online License Server in installer to 5.5.4
Chaos Cloud
  • Updated Chaos Cloud Client in installer to 1.13.0
Release Notes for V-Ray Next for Unreal, update 3.2
Official Release
Date – March, 2021
New Features
Unreal Engine
  • Support for Unreal Engine 4.26
Modified Features
License Server
  • Updated Online License Server in installer to 5.5.3
Chaos Cloud
  • Updated Chaos Cloud Client in installer to 1.1.0
Release Notes for V-Ray Next for Unreal, update 3.1
Official Release
Date – October, 2020
Modified Features
Installer
  • Improved installer initialization speed
.vrscene Import
  • Grouping of objects in World Outliner based on type and layers in host DCC
.vrscene Export
  • Improved exported .bat file when exporting light bake atlas .vrscenes
Bug Fixes
V-Ray Bake
  • Light map EXRs modified in Photoshop import as black
  • Process Atlases not extracting EXRs from a very long path
  • Failed to export EXRs to a non-latin name path
.vrscene Import
  • Crash on reimport of Light mesh in UE 4.25
.vrscene Export
  • Port number doesn't export correctly in generated .bat file
Official Release
Date – June, 2020
New Features
Chaos Cloud
  • Support for Chaos Cloud - Rendering and Light baking (info)
 UX
  •  Notification if the user is rendering in the viewport with disabled realtime option
Materials
  • Added SideColor option representing Fresnel in VRayMtl (info)
MAX Script
  • V-Ray Material Optimizer MAX script for texture baking and material simplification  (info)
Modified Features
License Server
  • Updated Online License Server in installer to 5.5.0
Bug Fixes
Materials
  • Serialization mismatch crash in certain situations with AlphaComposite blend mode in VRayMtl
  • Refraction input clamping colors above 1.0
Lights
  • LightMesh not exporting correctly when set to "Invisiblе"
Installer
  • Standalone Render Server installation fails to locate vray.exe
Release Notes for V-Ray Next for Unreal, update 2.7
Official Release
Date – May, 2020
New Features
Unreal
  • Support for Unreal Engine 4.25
 V-Ray Bake
  • Process Atlases - Extract light maps from single or multiple atlases saved in .exr files (info)
  • Export Light bake .vrscenes from the V-Ray Scene Export Options (info)
 Lights
  • Support for V-Ray mesh lights  (info)
  • Support for Unreal Sky light  (info)
Render Elements
  • Support for Cryptomatte render element (info)
 Geometry
  • Initial support for Unreal Landscape Actor (info):
    • Landscape specific material expressions:LanscapeLayerBlend, LandscapeLayerCoords, LandscapeLayerSwitch, LandscapeLayerWeight, LanscapeVisibilityMask are not yet supported.
  • Support for Static and Dynamic Shadow casting for Actors
 Packaging
  • V-Ray materials can now be packaged for mobile platforms
Modified Features
.vrscene Import
  • Imported static meshes have assigned materials
Bug Fixes
V-Ray Bake
  • Crash when aborting light bake
Geometry
  • Error when hidden Brush geometry
Release Notes for V-Ray Next for Unreal, update 2.6
Official Release
Date – January, 2020
New Features
 Unreal
  • Support for Unreal Engine 4.24
 Geometry
  • Support for Unreal Brushes geometry
 UI
  • Track Active Render View option to get the current render view aspect ratio being it either camera filmback settings or viewport in V-Ray Settings (info)
Modified Features
V-Ray
  • Improved speed on render and .vrscene export initialization
.vrscene Export
  • Generates .bat file to be used in standalone rendering (info)
VFB
  • Improved speed when opening VFB
Bug Fixes
V-Ray
  • VFB history and adjustments settings resets when closing
  • Unreal material with Unlit shading model not generating GI
  • Export failed for Cube Texture with Default compression settings
  • Rendering expressions in different Normal spaces
  • Crash when rendering substance materials
Release Notes for V-Ray Next for Unreal, update 2.5
Official Release
Date – December, 2019
New Features
 Texture
  • Support for Color Corrections in Unreal texture asset editor
    • Brightness
    • Brightness Curve
    • Vibrance
    • Saturation
    • RGBCurve
    • Hue
 UI
  • Added shortcut from V-Ray drop-down menu to in Project settings (info)
  • OptiX render mode (Experimental) in V-Ray Settings tab (info)
  • Dedicated button and dialogue window to save .vrscene file
V-Bake
  •  Support for generating low quality(mobile) lightmaps when lightbaking
Modified Features
V-Ray
  • Improved speed when using Unreal materials in render and lightbake
UI
  • Moved VRay CUDA GPU Device Selection to V-Ray category in Project Settings (info)
.vrscene Import
  • Better .vrscene import progress reporting and monitoring
Bug Fixes
.vrscene Import
  • Crash when importing meshes without normal data
V-Ray
  • Bugs with Normal map input producing incorrect shading
  • "Affects World" property in Unreal lights not updating in IPR
  • Bug with Dome light texture rotation in interactive does not update properly
  • Crash when switching levels while rendering using VRayPhysicalCamera
  • Bug "Use Custom Start Frame" option in Sequencer not exporting properly
  • Exposure not exporting correctly in Sequencer animation when using "3d Max Compatible" in VRayPhysicalCamera
  • Exception in CORE when network error occurs and bitmaps fail to load
  • Directional light renders black with certain color values
  • V-Ray material thumbnail preview mesh might randomly disappear
Release Notes for V-Ray Next for Unreal, update 2.4
Official Release
Date – November, 2019
New Features
 UI
  •  Added V-Ray Icons in Modes panel to V-Ray Assets (info)
Camera
  •  Added Near Clip Plane functionality to VRayPhysicalCamera (info)
100
300
VRayPhysicalCamera Near Clip Plane Value
Modified Features
V-Ray
  • Support for Unreal expressions – SetMaterialAttributes, GetMaterialAttributes (info)
V-Ray Bake
  • Improved visual quality of shadows when lightbaking
Before
Current
Bug Fixes
V-Ray Bake
  • Fixed crash when rebaking actors and loading lightmaps
Release Notes for V-Ray Next for Unreal, update 2.3
Official Release
Date – October , 2019
New Features
V-Ray
  • Support for Unreal Engine 4.23 (Recommended use after 4.23.1)
  • Support for import automation of vrscene via python script (info)
  • Automatic saving of rendered still images in Unreal viewport when in non interactive mode  (info)
  • In-product update notifier (info)
Lights
  • Support for Temperature parameter in native Unreal lights
UI
  •  Functionality to cancel vrscene import (info)
Modified Features
UI
  • Modified UI of V-Ray Scene Import Options dialog (info)
  •  Animated render states for V-Ray Bake icon (info)
V-Ray
  • Support for Unreal expressions – RotateAboutAxis (info)
Installer
  • Updated Online License Server in installer to 5.2.3
V-Ray Bake
  • Improved speed processing and storing of rendered lightmap atlases (info)
Bug Fixes
V-Ray
  • Missing VRay CUDA GPU Device Select from UI
  • Actors with same ID Names not exporting correctly
  • Incorrect render elements settings when rendering sequencer animation
  • Crash when closing Unreal while rendering
  • Crash when Render Element Light Select has listed lights that are hidden in the level
  • V-Ray Settings are empty when Project Startup Map is set to None
Materials
  • Missing Shader Balls preview in Content Browser for V-Ray Materials
Release Notes for V-Ray Next for Unreal, update 2.2
Official Release
Date – August 29, 2019
New Features
V-Ray
  • Moved to CORE version 4.20
  • Render resolution and Lightmap Atlas resolution presets
  • Lightmap baking progress bar
Geometry
  • Support for Cast Shadows option for Static Mesh Actors
Textures
  •  Support for "Flip Green Channel" option in Normal textures
Modified Features
Import
  • Improved the import of GeomMeshFile with identical vrmeshes
Installer
  • Removed the check for running Epic Games launcher when installing the plugin
Materials
  • Improved support for Unreal expressions - VertexColor, ObjectRadius, ObjectPositionWS
Bug Fixes
V-Ray
  • Static Meshes with zero area UVs cause an Exception in CORE error when light baking
  • Camera rotation bug when orbiting around mesh with ALT+Mouse
  • Resolution capped to 11585
  • Assertion crash with viewport rendering when using DX12
  • Preparing scene progress goes above 100%
  • Switching between level maps does not stop rendering or baking process
  • Two Sided option not exporting correctly with VRayMtl, VRayCarpaintUberMtl, VRayPBRMtl
Release Notes for V-Ray Next for Unreal, update 2.1
Official Release
Date – July 18, 2019
Bug Fixes
V-Ray
  • V-Ray Light Bake memory leak
  • Issue with support of multiple GPUs
  • Issue with transparent native materials in Light bake
Official Release
Date – June 26, 2019
New Features
V-Ray
  • Export/import functionality of lightmaps
Lights
  • Rendering of DatasmithAreaLight
Camera
  •  Quadratic and Cubic distortion types to VRayPhysicalCamera
Modified Features
V-Ray
  • Project path is new default directory for "Export VRScene Path" option
Lights
  • Point Light Source radius working in IPR
Materials
  • Improved support for Unreal expressions - TwoSidedSign, Time
Bug Fixes
V-Ray
  • Static meshes with identical names in different folders do not render correctly
  • Lights in Blueprints are exported at BP pivot point
  • "Use Local Host" option not working in Light bake
  • "Cannot send asset" error when in DR
  • Incorrect Lightmaps is applied when some level actors are hidden
  • CUDA Error 700 when "Export failed for the ... texture"
  • CUDA error 700 when baking TwoSidedFoliage material
  • "Error in last lightbake: File write error"
Release Notes for V-Ray Next for Unreal, update 1
Official Release
Date – May 28, 2019
New Features
V-Ray
  • Support for Unreal Engine 4.22
  • Toggle option for sky in VRaySunAndSky
  • Option to remove local host from DR
  • "Transfer Missing Assets" option in DR
  • Progress report logging when computing long task
  • Directional parameter in VRayLightRect
  • Light options to V-Ray Lights - Affect Diffuse, Affect Specular, Affect Reflections
  • Support for Specular Scale for Unreal lights
Modified Features
V-Ray
  • Viewport rendering with Translucent shading model
  • Speed and memory utilization when V-Ray Light Bake
  • Support for Unreal shading models - Subsurface, Two Sided Foliage
  • Support for Unreal expressions - Pixel Depth
  • UI layout in V-Ray Settings and V-Ray Light Bake Settings
Bug Fixes
V-Ray
  • Bug with lightmaps having offset
  • Performance slow down during UV tree preparation in V-Ray Light Bake
  • Crash in cooked games packaged in Shipping configuration
  • Issues with metallic or highly reflective materials to appear black after V-Ray Light Bake
  • Intensity mismatch between viewport and render when using Directional Light
Official Release
Date – March 13, 2019
New Features
V-Ray
  • Viewport rendering functionality
  • Support for Unreal tonemapper and post effects (in viewport rendering only)
  • Dedicated V-Ray Bake settings
  • Telemetry
Modified Features
V-Ray
  • Dome Tex Resolution parameter in VRayLightDome blueprint
  • Functionality for creating, deleting and hiding actors in the level while in IPR rendering
  • Support for "Tangent Space Normal" checkbox option in Material
  • Support for Unreal expressions: Arccosine, Arcsine, Arctangent, Arctangent2, Logarithm2, Tangent, World Position
Installer
  • Updated Online License Server in installer to 5.2.2
Bug Fixes
V-Ray
  • "Launch V-Ray Render Server (Unreal)".exe file path
  • Issue with Sky texture not updating in IPR
  • Issues when using Normal maps in Materials
Release Notes for V-Ray Next for Unreal, Hotfix 3
Official Release
Date – February 01, 2019
New Features
V-Ray
  • Support for rendering Unreal materials with V-Ray Hybrid rendering on both CPU and GPU
  • Added the VRayMtl, VRayPBRMtl and VRayCarpaintMtl to the V-Ray Category in the Add New drop down menu in the Content Browser
Modified Features
V-Ray
  • Support for Unreal Shading Models: Clear Coat
  • Interactive update for native Unreal materials.
  • Support for Unreal expressions: Bump Offset, CameraPositionWS, ConstantBiasScale, ReflectionVectorWS, Screen Position, SphereMask, TransformVector, VertexNormalWS, ViewProperty
  • Error reporting for unsupported Unreal materials, expressions, blend modes and shading models
Installer
  • Updated Online License Server in installer to 5.2.1
Bug Fixes
V-Ray
  • Errors due to NVidia driver dependencies
  • Crashes if unsupported expressions, blend modes and shading models are used
Release Notes for V-Ray Next for Unreal, Hotfix 2
Official Release
Date – December 05, 2018
Modified Features
V-Ray
  • Support for Unreal Engine 4.21
  • Support for Unreal expressions - Ceil, Floor, FMod, Frac, If, Min, Round, Sign, Truncate expressions
Light Bake
  • Improved speed of light bake
Bug Fixes
V-Ray
  • V-Ray exporter in sequencer
    • Export for custom start frame
    • Export for sequencer camera cuts using multiple cameras
    • Difference in color space in VFB and saved image
    • VRay CUDA GPU Device Select not working with sequencer animation
Release Notes for V-Ray Next for Unreal, Hotfix 1
Official Release
Date  November 15, 2018
Modified Features
V-Ray
  • Responsiveness of UI during interactive render
Light Bake
Installer
  • Updated Online License Server in installer to 5.1.2
Teleport Blueprint
  • Updated Teleport BP to get exposure from listed cameras
Bug Fixes
V-Ray
  • V-Ray not loading in Unreal if no supported devices are set in device select
    • Fallback to using CPU device if no supported devices are set in device select
  • Render Server shortcut not pointing to correct file path
Light Bake
  • Light bake not using devices set in V-Ray CUDA GPU Device Select
  • CUDA error during light baking
Official Release
Date  November 08, 2018
New Features
V-Ray
  • Log V-Ray messages in Unreal's Message Log
  • Basic support for importing Displaced Static Meshes
  • Output a list of the Static Meshes in the atlas currently baked
Modified Features
V-Ray
  • Support for Unreal Materials - Masked, Translucent, Alpha Composite Blend Modes and Unlit Shading Model
Bug Fixes
Light Bake
  • Crash when light baking Static Meshes with overlapping UVs
Release Notes for V-Ray Next for Unreal, beta 2
Beta release
Date – October 30, 2018
New Features
Light Bake
  • Initial implementation of V-Ray Bake
Materials
  •  Initial support for Unreal native materials
Geometry
  • Support for Foliage system
Render
  • Initial support for Sequencer animation
Modified Features
Installer
  • Request confirmation about version being uninstalled during installation process
UI
  • Reworked UI
  • Integrated GPU device select tool in V-Ray Settings
  • Global Shadow Bias parameter
  • Fallback material for use when rendering unsupported materials
  • Quick settings quality presets slider
  • Export VRScene path option
  • Auto Exposure and Auto White Balance options
  • Undersampling option
Camera
  • Support for Depth of Field in VRayPhysicalCamera
Materials
  • Improve parity for VRayMtl material
  • Support for SeflIllumination material
  • V-Ray Materials are now included in the packaging/cooking process
Lights
  • Updated VRaySunAndSky sky model
  • Support for Unreal Intensity Units in Lights
  • Support for 4.20 RectLight
  • Support for Light Source Angle in Directional Light
  • Support for default intensity unit at import for Spotlight, Omni, Sphere Light, Rectangle Light
Geometry
  • Improved support for VRay Proxy (vrmesh)
Render
  • Update responsiveness and speed of IPR
  • Support for interactive mesh material update
  • Support for interactive material parameters update
  • Stop renderer when noise threshold is reached in non-interactive session
Render Elements
  • Added :
    • NVidia AI Denoiser
    • Background, GI, Lighting, Reflection, Refraction, Specular, Self Illumination, Sub Surface Scattering
    • Diffuse Filter, Reflection Filter, Refraction Filter, Shadows, Atmosphere
    • RenderID
    • Normals, Bump Normals, Sampler Info, Velocity, ZDepth
    • Light Select
    • Sample Rate, Unclamped Color, Noise Level
VFB
  • Dedicated button for opening the VFB
  • Always on top VFB
VR
  • V-Ray Teleport Blueprints separated in an additional plugin
Beta release
Date – April 05, 2018
New Features
vrscene Support
  • Automatic convert of materials and lights into real-time equivalents for UE workflows
  • Keeping original materials from the imported vrscene connected to their real-time versions and are using them for raytraced rendering
Camera
  • Support for the VRayPhysicalCamera
  • Support for the 3ds Max’s Physical Camera
  • Initial implementation of exposure and color mapping
Materials
  • Support for VRayMtl material (including partial VRay2SidedMtl)
  • Initial implementation of a PBR material
  • Initial implementation of an easy to use car paint material
  • V-Ray materials are supported natively in UE and are working with Lightmass baking, Lights, Reflection probes, Post process materials, Blueprints
Lights
  • Support for VRayLightDome, VRayLightRectangle, VRayLightSphere, VRayLightIES, UE Spot light, UE Point light, UE Direct light
  • Initial implementation of the V-Ray Sun&Sky system
Render
  • Initial implementation of interactive rendering
  • V-Ray Hybrid rendering on both GPU and CPU
  • Using the V-Ray Next GPU engine
Distributed Rendering
  • Support for DR
Render Elements
  • Support for the V-Ray Denoiser
Textures
  • Support for VRayTriplanarTex
VFB
  • Support for the VFB
  • Render History window implemented
VR Mode
  • Support for the VR mode in the Unreal Editor
