This page provides information on the V-Ray Simple Mix Texture.
The Simple Mix texture allows a texture to be multiplied with a color.
Simple Mix texture is called Combine Color texture in all versions until V-Ray version 3.60.
Any texture can be replaced via the Replace With New Texture (
) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
The middle section of the image represents a mix between Texture (left) and Color (right)
Color / Texture – Specifies a color and a texture.
Blend amount – Specifies the amount of blending between the color and texture.
Multiply Result – Multiplies the result.
Invert Result – When enabled, inverts the result.
