width55%
Corona Sun allows you to add a realistic and physically correct source of day light for illumination of the scene.
By default, the sun height in the sky adjusts the color of the sun realistically. It always generates "soft" shadows since it is physically realistic.
You can adjust the size of the sun if required, with a larger sun creating softer shadows. Rather than have the sun color and intensity controlled automatically, you can choose to manually override it and set it to a specific color and/or intensity.
width45%
Corona Sun
width55%
On – Turns on and off the sun lightsunlight.
Targeted – Makes the Corona Sun targeted.
0 object excluded – Excludes objects from illumination/shadow casting for the sun lightsunlight.
Add Corona Sky environment – Adding the Corona Sky Map procedural texture map to illuminate the scene with a realistic skylight.
Intensity – Specifies an intensity multiplier for the Corona Sun.
Size – Makes the shadows softer/sharpensharper.
Shadowing from clouds – If enabled and the sun is selected in a sky map with enabled clouds, the sun will be shadowed by these clouds.
Color
Realistic – Changes Corona Sun color, depending on the position of the sun.
Textured – When enabled, there are subtle color differences towards the borders/horizon. Enabling this option can slow down the rendering and produces no visible differences, except when the sun is viewed directly in detail, so there is usually no need to enable it. When disabled, the sun disc has uniform color on its entire surface.
Direct input – Specifies color using the Corona Color Picker.
Kelvin temp – Adjuststhe Corona Sun color temperature according to the Kelvin Temperature Scale.
Visibility
Visible directly – Makes the Corona Sun directly visible to the camera.
Visible in reflection – Makes the Corona Sun directly visible in reflections.
 Visible in refraction – Makes the Corona Sun directly visible in refractions.
 Generates caustics – Enabling this option generates caustics.
width5%
width40%
Image RemovedImage Added
Examples
width50%
Corona Sun Size
Image slider
Panel
titleSun size 0.1 (min value)
Panel
titleSun size 1 (the default value)
Panel
titleSun size 5
Panel
titleSun size 10
width50%
Corona Sun Intensity
Image slider
Panel
titleSun intensity 0.1
Panel
titleSun intensity 0.5
Panel
titleSun intensity 1 (the default value)
Panel
titleSun intensity 5
width50%
Corona Sun Kelvin temperature
Image slider
Panel
titleKelvin temp - 6500 (default value)
Panel
titleKelvin temp - 5000
Panel
titleKelvin temp - 4000
Panel
titleKelvin temp - 3000
Panel
titleKelvin temp - 2000
Panel
titleKelvin temp - 1000 (min value)
width50%
Corona Sun position
Image slider
Panel
titleSun possition 1
Panel
titleSun possition 2
Panel
titleSun possition 3
Panel
titleSun possition 4
Panel
titleSun possition 5
