This page provides information on the Live Link feature from Cinema 4D in Chaos Vantage.
width50%
The Live Link feature makes it possible to instantly see changes made in Cinema 4D without the need to export and import .vrscenes in Chaos Vantage.
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/bePWHWDWYJ0" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Live Link Setup
For Live Link to function properly, please follow the steps below.
UI Text Box
typenote
Live Link works only with officially released V-Ray 5, update 2 or later versions.
width50%
1. Download and install the latest official V-Ray for Cinema 4D build from the download button. Make sure you have appropriate licenses. If you experience problems, please contact Chaos Support using the online form.
UI Text Box
typenote
The Live Link scripts are automatically installed with V-Ray 5 for Cinema 4D, update 2 and later.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload VRay for Cinema 4D
urlhttps://download.chaosgroup.com/?platform=70&product=47
width50%
2. Download latest Chaos Vantage build from the download button. Make sure you have appropriate licenses. If you experience problems, please reach us using the Support Form.
width5%
width45%
Align
alignright
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Chaos Vantage
urlhttps://download.chaosgroup.com/?platform=47&product=63
Initiating Live Link from Cinema 4D
width55%
Live link can be initiated from the V-Ray menu > Vantage Live Link button.
This initializes a live link session between Cinema 4D and Chaos Vantage.  It automatically:
Fancy Bullets
typecircle
    • Starts Chaos Vantage if it is not already running;
    • Sends the scene to Chaos Vantage on 20701 port
UI Text Box
typenote
Please, always make sure you are using the same port in both Cinema 4D and Chaos Vantage!
In Cinema 4D, you can set it by clicking the Settings button () and opening the Vantage Live Link Options window.
In Chaos Vantage, go to Live Link > Change Port... and open the Enter Live Link Port window.
width5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/nA6XKl-IL9s?list=PLm2Irfq-UvZ3h2Sxw2FVd9qjOIpqHOLiG" title="Using Live Link from Cinema 4D to Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Image Removed
width55%
Once a Live Link session is started, the scene is transferred to Chaos Vantage. A thick blue contour line appears around the viewport and the status message in the lower right changes to [LIVE LINK].
In Cinema 4D's viewport, the Vantage icon () appears in the lower right corner.
To stop a Live Link session, click again the Vantage Live Link button in the V-Ray menu.
width5%
width40%
Supported Features
The following changes made in Cinema 4D are propagated through Live Link:
Fancy Bullets
typecircle
  • Editing, creating and deleting of:
    • Camera
    • Geometries
    • Lights
    • Materials
    • Textures
    • Environment
Excerpt Include
Live Link
Live Link
nopaneltrue
Fancy Bullets
typecircle
  • Live Link is not supported on macOS
