This page provides information on the Corona Physical Material, its settings, and usage.
Section | |||||||||||||||||||
Section |
Why was it
added?
The Corona Physical Material was added as the replacement of the old Corona Material. Some of the benefits of the Physical Material include:
Fancy Bullets | ||
How is it
better than the old Corona Material (now called Legacy Material)?
There are many benefits over the old CoronaMaterialCorona Material. For starters, Corona Physical Material offers a natural way to set up realistic materials, making various workflows much more intuitive and simpler in the long run. Its Its diffuse calculations have been switched from Lambertian to the Oren-Nayar model, so even the simplest of materials will now look better and be rendered more physically correct.
In addition, fake and non-physically plausible material properties are not possible anymore, the current material parameters are designed in a way to prevent such cases.
When to use the Corona Physical Material?
The Physical Material should primarily be used as the new default for any newly created materials, unless it is absolutely necessary to use the Corona Legacy Material (e.g. in case of re-rendering older scenes in Corona Renderer 7 or newer).
Corona Physical Material Settings
Section | ||||||||||||||||||||||||||||||||||||
Media options
Advanced options
