This page provides information about the Matte Shadow Render Element in V-Ray for Cinema 4D.
width57%
The Matte Shadows Render Element shows areas where light doesn't reach. Compare this with the Raw Shadow Render Element, which gives areas of cast shadows. While technically not part of the Beauty render elements, the Matte Shadow Render Element can be used to lighten cast shadows by adding it to the Raw Light Render Element. It can also be used to assist in adding 3D elements to a background image or footage in the composite.
UI Path: ||V-Ray|| > Render Elements > Matte Shadow
width5%
width38%
Multiexcerpt include
MultiExcerptNameAddBackground
PageWithExcerptAtmospheric Effects RE
How to add a render element to a scene
width57%
Enable Deep Output –  Specifies whether to include this render element in deep images.
Color Mapping –  – Applies the color mapping options specified in the Color mappingMapping rollout of the V-Ray tab in the Render Settings window to this render element.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
width5%
width38%
