This page provides information about Raw Shadow Render Element in V-Ray for Cinema 4D.
width
62%
The Raw Shadow Render Element stores information about cast shadows calculated from the lighting in the scene. It is a "reverse" image in the sense that white areas indicate shadows while black areas indicate no shadow.
UI Path: ||V-Ray|| > Render Elements > Raw Shadow
width
5%
width
33%
Multiexcerpt include
MultiExcerptName
AddBackground
PageWithExcerpt
Atmospheric Effects RE
How to add a render element to a scene
width
62%
Enable Deep Output– – Specifies whether to include this render element in deep images.
Color Mapping – – Applies the color mapping options specified in theColor mappingMapping rollout of the V-Ray tab in the Render Settings window to this render element.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – – Applies the post-render color adjustments made from the VFB.
