HideElements | ||
UI Text Box | ||
V-Ray 6 for 3ds Max supports 3ds Max 2018–2023. Several V-Ray features require 3ds Max 2019 or newer to work, including V-Ray Proxy hierarchy, batch loading multi-sub textures, faster UI, and Chaos Cloud collaboration from the VFB. |
Requirements
The requirements listed here are for the latest version of V-Ray for 3ds Max.
Please make sure that your system meets the requirements listed below before installing V-Ray.
Processor | Intel 641, AMD64 or compatible processor with SSE4.2 support |
RAM | Minimum 8 GB RAM, recommended 64 GB RAM |
Operating system | Microsoft® Windows 10 or Windows 11 operating system |
Autodesk® 3ds Max | 3ds Max® 2018, 2019, 2020, 2021, 2022, 2023, and 2023 2024 (64-bit) |
USB port | Required for customers using legacy hardware lock, preferably USB 2.0 |
TCP/IP | Only IPv4 required for distributed rendering is supported. IPv6 is currently not supported. |
License Server | 6.0.0 or later |
GPU Acceleration | NVIDIA CUDA with minimum required compute capability 5.22: Maxwell-, Pascal-, Volta-, Turing-, and Ampere-based NVIDIA card(s); NVIDIA RTX with compute capability 5.22: RTX cards with latest recommended video driver3; 2GB VRAM V-Ray Production Denoiser: AMD or NVIDIA GPU supporting OpenCL 1.2; NVIDIA AI Denoiser: Maxwell-, Pascal-, Volta-, Turing-, and Ampere-based NVIDIA card with latest recommended video driver3 |
