This page provides information about the Hair material in V-Ray for.
Section | |||||||||||||||
UI Paths
||V-Ray Asset Editor|| > Materials (right-click) > Hair
||V-Ray Asset Editor|| > Create Asset (left-click) > Materials > Hair
UI Options
Diffuse
Primary Specular
Secondary Specular
Transmission
Anchor | ||||
Example: Transmission Glossiness Length and Width Parameters
This example shows the effect of the Transmission Glossiness Length and the Transmission Glossiness Width parameters. It shows a number of vertical strands (in this case, produced by VRayFur) lit from behind by a spherical light.
Note how each parameter changes the way light scatters along the length and the width of the strands. Higher values for the length glossiness compress the transmission highlight along the strand length, while lower values expand it.
Section | |||||||||||||||||||||||||||||||||||||
Options
Anchor | ||||
Example: Opaque for GI
This example shows how important GI is for the appearance of hair, especially bright hair. GI is brute force and light cache has retrace.
Multipliers
Binding
Override Control
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Settings.
Attributes
The attributes from the following expandable menus are available for the Hair material.
Anchor | ||||
Expand | |||||||||||||||||
Raytrace Properties
Expand | ||||||||||||||||||||||
Material ID
