changes.mady.by.user Kristina Gaytandzhieva
Saved on Dec 04, 2023
Saved on Dec 08, 2023
||V-Ray|| > OSL Material
||Create|| > V-Ray > OSL Material (disabled Separate menu for V-Ray materials)
Shader File – Specifies the .osl or .oso file which contains the shader (object) code.
Closure Output – Specifies the closure color source for the material's output. The built-in output closure color parameter Ci is selected by default.
Max Ray Depth – Specifies the maximum reflection/refraction depth for the shader.
Reload Shader – Reloads the Shader File.
Recreate Attributes – Reloads the Shader File and recreates its attributes
