width57%
V- Ray Toon is a very simple node that produces cartoon-style outlines on objects in the scene. This includes both simple, solid color shading but also outlined borders on the edges of the object(s).
The result of this rendering effect can now be stored in its own V-Ray Toon Render Element.
Combine with the V-Ray Toon Material or V-Ray Toon Node Material to enhance the cartoon effect.
UI Expand
titleUI Path: ||V-Ray menu|| > Volumetrics > V-Ray Toon
width15%
width70%
c4d2024_62000_Toon_VrayMenu_UI.pngImage RemovedImage Added
width15%
width5%
width38%
