width60%
The Emissive material layer is created with the Add Layer option  option in the V-Ray Asset Editor. The parameters are the same as the Emissive material however, this layer can not be overridden.
UI Text Box
typenote
Some parameter options are available only in Advanced mode.
width5%
width35%
