This article provides information on the Corona Decal object, its settings, and usage examples.
Floatingpagetoc |
Section | ||||||||||||||||||
Section | |||||||||||||||||||||
Affect Base
Section | |||||||||||||||||||||||||||||||||||||||||
Creating a Corona Decal
To create a Corona Decal use the dedicated Corona Toolbar icon. It can also be accessed by typing Decal into the 3ds Max X menu or from the Command Panel > Create > Geometry > Corona > CDecal
Workflow
Let's create a simple material and apply it to the Corona Decal object.
UI Text Box | ||
Use the "Fit to.." option to automatically adjust the Decal's width and height. |
Let's start Interactive Rendering in the viewport.
Max Angle Limit
Corona Decals can form a stack. The projection order is based on the decals' vertical position - over or under another decal.
Affect Base
Section |
Starting with Corona 10, you can specify which base object(s) material channels a Corona Decal should affect. Both the decal and the base material need to be CoronaPhysicalMtl in order for decal channels to work properly! If a channel is enabled, it replaces the corresponding base object material channel where the decal is projected. If a channel is disabled, e.g. Color - base object material color will be used instead. |
Section |
Bump and Displacement channels have an additional option - they can be added to the base layer. If "Add to base" is disabled for Bump or Displacement, they will replace the corresponding base layer: |
Example
Overlaying many decals with varying vertical positions and options can quickly produce good-looking results:
