width57%
Caustics Subdivs – Only used when calculating Caustics. Lower values mean more noisy results but render faster. Higher values produce smoother results but take more time.
Caustics Multiplier – This value is a multiplier for the generated caustics by the selected object. Note that this multiplier is cumulative - it does not override the multiplier in the Caustics render settings rollout section.
width5%
width38%
Project
width57%
Project is used to create a list of objects that can be excluded (or included) from the light's effects.
Mode – Specifies whether the objects in the list are considered Included or Excluded from the light's effects.
Objects – Creates a list of objects to be excluded or included. When an object is added to the list, the Image Added icons appear, which determine how the light affects the object. The Image Added icon controls whether the emitted light affects the object. The Image Added icon controls whether the shadows caused by the light affect the object. The Image Added determines whether the object's children are affected.
width5%
width38%
