Rotates the instances From the given degrees up To the given degrees continuously. A map can be applied. If it is enabled for a given axis, its rotation values are overwritten by the map. RGB maps can be used to control the rotation of each axes individually ( Red = X; Green = Y; Blue = Z). Grayscale maps control the rotation of all axes proportionally.
Step Size – Specifies the random step size.
Normal Alignment – When a value, different than 0 is entered, the instances are aligned according to the world up axis. This is useful when the host object is curved and the scattered objects need to remain vertical, not follow the curve of the surface. Positive values mean that the instances are aligned to the +Z axis (vertical up) and negative values mean that the instances are aligned to the -Z axis (vertical down).
Preserve Rotation – Preserves the original rotation of the objects.
width
5%
width
35%
Image RemovedImage Added
Random Scale
width
60%
Scales the instances From the given value To the given value continuously. When Uniform scale is enabled, the X axis values are applied on the whole Distribute-on target object. A map can be applied. If it is enabled for an axis, the values of that axis are overwritten. RGB maps can be used to scale axes individually ( Red = X; Green = Y; Blue = Z). Grayscale maps control the scale of all axes proportionally.
Uniform Scaling – When enabled the X axis values are also used for the Y and Z axes.
Preserve Scaling – Preserves the original scaling of the objects.
