width60%
Right-click on the component to open V-Ray Material from File context menu.
Use the options to import your materials or use the material presets from Material Library or Cosmos Materials.
Note that invalid input file paths are auto-resolved as long as the files reside at the same location as the .gh project file
width10%
width25%
Example: Material from File
Download the GH definition here.
width54%56%
VRay6.2.2_GH_Material_From_FileVRay6.2.2_GH_MaterialFromFile_DefinitionImage Modified
width46%44%
Example: Vertex Color Setup
