To run V-Ray, you have to:
Progress Bar Container
step1
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
url Installation
titleStep 2: Activate your license
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Houdini
urlV-Ray Configuration
width55%
This guide provides steps
width45%
on installing V-Ray for Houdini.
Trial users should refer to the Trial installation of V-Ray for Houdini, as the process differs from the one shown here.
The V-Ray installer can be unpacked from a zip file.
UI Button
colorblue
newWindowtrue
icondownload
titleDownload the latest V-Ray for Houdini installer
urlhttps://download.chaosgroup.com/?platform=58&product=47
V-Ray for Houdini installation can be done via an installer or via a zip file. The Please check the system requirements before installation. he V-Ray installer automatically removes any previous V-Ray for Houdini versions. If you experience problems, you can manually uninstall the previous versions to perform a clean install.
Follow this step-by-step guide to set up the V-Ray installation via an installer.
Trial users should refer to the Free Trial page, as the process differs from the one shown here.
width5%
width50%40%
Installing V-Ray for Maya gives you access to:
Fancy Bullets
typecircle
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/EvEm7-h5qHY" title="V-Ray for Houdini — Installation" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Running the Installer
Before running the installation, make sure your OS account has administrative privileges.
UI Steps
sizesmall
UI Step
width50%60%
End User License Agreement
Please take a moment to review the License Agreement.
Once you've carefully read the License Agreement, you can click "I accept the Agreement" if you agree to the terms.
Proceed to click the Install button. If you need to customize your V-Ray installation, click the Advanced button.
width5%
width45%35%
UI Step
width50%60%
Install Directories
Advanced settings
Here, you can specify the installation paths for V-Ray for Houdini and the Houdini Packages. Please check if the default folders are correct.
Expand
titleClick here to see the default paths for all OS.
Windows default folders:
Code Block
C:\Program Files\Chaos Group\V-Ray\Houdini####
C:\Program Files\Side Effects Software\Houdini##.#.###\packages
macOS default folders:
Code Block
/Application/Chaos Group/V-Ray/Houdini##.#.###
/Application/Houdini/Houdini##.#.###/Frameworks/Houdini.framework
Linux default folders:
Code Block
/usr/Chaos Group/V-Ray/Houdini##.#.###
/usr/Side Effects Software/Houdini##.#.###/packages
UI Text Box
typewarning
The V-Ray installer automatically sets default paths, which are configured for the latest version of Houdini. If you use an earlier version of Houdini, please be aware that you may have to manually add the correct paths for your specific version.
Help make V-Ray even better – Participate in the improvement decisions for future versions of V-Ray. No intelligence property is violated when agreeing to participate in the feedback program. Chaos does not gather scenes, assets, materials, etc. What Chaos receives is user preferences on just a few key render settings and the resulting render times. The point of this feature is to improve V-Ray's performance and the user experience. For more information, see the Chaos Telemetry page.
width5%
width45%35%
UI Step
width50%60%
Licensing
In this step, you can specify whether the V-Ray license server Chaos License Sever runs locally or on another machine.
If you select Remote licensing,you have to fill in the IP address of your V-Ray license server Chaos License Server in the Primary License Server field. Leave port 30304 unchanged. An Alternate License Server can be used for redundancy in case the primary one does not respond. The License Server will not install when the Remote option is selected.
width5%
width45%35%
width50%60%
If you select the Local option, you can select whether you want to install the Chaos License Server, or use the one already installed, if any.
width5%
width45%35%
UI Step
width50%60%
Chaos License Server Options
At this step, you can choose the license server directory.where to install the Chaos License Server:
Windows default path: C:\Program Files\Chaos\VRLService
macOS default path: /Application/Chaos/VRLService
Linux default path: /usr/Chaos/VRLService
Migrate data during installation – When enabled, it transfers all of your settings made with earlier versions of Chaos License Server, such as proxy settings, etc. Disabling this option makes a clean install of Chaos License Server with any custom settings from previous installations reset to their defaults.
Add firewall exception – When – When enabled, the default licensing port (TCP 30304) can pass the firewall. If you disable it at this step, you need to manually must manually add firewall exceptions later. This option is available for Windows OS only.
width5%
width45%35%
UI Step
width50%60%
Installation Process
After you click the Install button, the installer proceeds to uninstall any previous versions and installs V-Ray on your machine.
If the installer detects any applications that need to be closed, it shows an error before being able to continue. Please close the applications and click Continue anyway, or restart the installation.
Once V-Ray installation has finished, the Chaos Cloud client installation starts. Note that the download process might take a while.
width5%
width45%35%
UI Step
width50%60%
V-Ray installation is successful.
width5%
width45%35%
Licensing V-Ray
Once the Chaos License Server installation is complete, you are directed to the Chaos License Server local host (127.0.0.1:30304) in order to sign in.
Image Removed
UI Text Box
typenote
The Chaos License Server will skip its installation process for two reasons:
  • If it detects a previous installation of the Online License Server on your machine.
  • If you choose the Remote V-Ray license server on the network option.
For full information on the Chaos License Server options and settings, see the Licensing section of the documentation.
Loading the V-Ray Shelf
When starting V-Ray for Houdini for the first time, you need to manually load the V-Ray Shelf. From the Houdini shelf, click the plus + icon, navigate to Shelves, and select V-Ray from the list.
Image Removed
Selecting a Renderer
Next Step
Go to step 2 to activate your Chaos License.
step1
url Installation
To render with V-Ray, simply click the Render button from the V-Ray Shelf. This automatically creates a vray_renderer node in the Network Editor (if one is not already present) and launches the V-Ray Frame Buffer.
