HideElements
cssselector#tocVertical, #tocHorizontal
Defining camera position
One of the first things you'd want to do is control your camera. This is done through the RenderView plugin. You will always want to create and setup this plugin, exactly one, in your scenes. (The exception is when you are Texture Baking - then you'd use BakeView.)
