This page is a tutorial on how to use resumable rendering with V-Ray for Cinema 4D.
Resumable rendering allows you to resume incomplete renders from where they left off in the previous session. The rendering may have stopped due to any number of reasons such as a power failure or having the job bumped off a machine or a render farm, or perhaps you stopped the render manually and want to start from where you left off.
Resumable rendering uses sidecar files for tracking checkpoints. For Bucket sampling, it uses a .vrimg file, and for Progressive sampling, it uses a .vrprog file.
How it Works
Resumable renders are possible with both Bucket and Progressive Image Sampler types:
UI Text Box | ||
Resumable Rendering is also compatible with Distributed Rendering. |
Section | ||||||||||||||||||||||||||||||||||||
Workflow
Fancy Bullets | ||
