This page provides information about the Invert node in V-Ray for Cinema 4D.
HideElements
cssselector#tocVertical, #tocHorizontal
width55%
 The V-Ray Invert is a utility node used to invert texture colors.
width5%
width40%
Properties
width55%
Input – Specifies the texture that has its colors inverted.
Invert Alpha – When enabled, the alpha is inverted as well.
width5%
width40%
