This page provides information about the User Integer node in V-Ray for Cinema 4D.
HideElements
cssselector
#tocVertical, #tocHorizontal
width
57%
The User Integer node texture allows the user to read and return a single integer value from the currently shaded object as a result. This can be useful if the same material or texture is applied to several objects in the scene, but you want to control some of its properties with user-defined properties.
