width60%
Distribute on-target objects – Specifies the object(s), on which the instances will be scattered.
Factor – This option is only available when Surface Scattering is set to Random or the scattering mode is set to 3D - In Bounding Box. Determines how many instances are scattered on the currently selected Distribute on-target object.
Instanced model objects – Specifies the objects which will be scattered on the distribute on-target object(s).
Frequency – This option is only available when there are more than one Instanced model objects. Determines the frequency of the currently selected instanced object in relativity to the others.
Override node propertiesWhen enabled, the node properties for the scatter node override those of the individual instanced model objects. (e.g. primary and secondary visibility, V-Ray matte options, etc.) Object ID override is not supported yet.
UI Text Box
typeinfo
Scattering of linked objects is also available. Import linked objects/groups/hierarchies as a group in the Instanced model objects field.
UI Text Box
typenote
A spline cannot be added to more than one list. For example, if a spline is added to the Distribute-on-target objects list, it cannot be simultaneously added to the Spline excludes list. It must be removed from one list before being added to the other.
width35%
Scattering
width60%
Spline includes – Scatters the models only inside the splines included in this list. The splines cannot be the same as the Distribute-on target objects.
Spline excludes – Scatters the models everywhere on the Distribute-on target objects, except in the areas where the splines from the list are located. The splines cannot be the same as the Distribute-on target objects. This option is useful, for instance, for removing instances of grass/trees from areas where a house needs to be located.
Near/Far – This option is only active when a spline from either list is selected. Determines the falloff distance from the selected spline to the selected axis plane (Projection). If the selected spline is from the Spline includes list, instances within the falloff distance are included. If the selected spline is from the Spline excludes list, instances within the falloff distance are excluded. For more information, see the Spline include Animation Example.
Scale – Scale factor further affecting the instances between the near and far falloff.
Density – Density factor further affecting the instances between the near and far falloff.
Projection – Specifies the axis on which to project the include/exclude spline onto the specified distribute-on target.
Expand
titleClick here to expand an example of the Projection parameter.
If you want to scatter objects on the ground, use the Z axis (projection from the top onto the ground). If you want to scatter the objects on a wall, use the X or Y projection (from left/right or front/back).
Max2024_VRay6.2_Scatter_ProjectionExampleImage Added
width5%
width35%
