HideElements
cssselector#tocVertical, #tocHorizontal
The following chart provides Diffuse and Reflection Color values that help you create realistic metallic shaders with V-Ray:
Base (diffuse) color
Reflection color
Metalness
Base color (web)
Red
Green
Blue
Red
Green
Blue
Silver
252
251
250
255
255
255
1
fefefd
Gold
244
202
104
255
250
195
1
fbe6ab
Copper
238
159
137
254
231
216
1
f8cfc2
Aluminium
231
233
235
245
250
252
1
f5f6f6
Chromium
142
141
141
145
142
176
1
c5c5c5
Lead
168
169
176
191
192
209
1
d4d5d9
Platinum
244
238
216
254
253
249
1
faf8ee
Titanium
246
240
209
254
254
250
1
fcf9ea
Tungsten
236
213
193
251
241
218
1
f7ece2
Iron
227
224
211
242
245
244
1
f3f1eb
Vanadium
242
228
199
254
251
242
1
faf3e5
Zinc
223
222
218
245
247
249
1
f1f0ef
Nickel
227
220
193
245
245
237
1
f3efe2
Mercury
199
199
199
224
232
240
1
e5e5e5
Cobalt
175
168
158
205
205
208
1
d8d4cf
* The exact hex values for V-Ray for Houdini can be found here: Metal Shaders
The Index of Refraction (IOR) plays an important role when creating a physically based material and has to be considered as part of the shader. For metallic materials (having Metalness value of 1) it is automatically calculated from the Diffuse and Reflection colors: see the Artist Friendly Metallic Fresnel paper. For materials with Metalness < 1, the Fresnel IOR parameter from the V-Ray interface is taken into account.
The site RefractiveIndex.info is a great resource for understanding the proper IOR of different materials.
UI Text Box
typenote
Note that in earlier V-Ray versions the Fresnel IOR still plays a role for creating physically accurate metallic shaders even if the Metalness is set to 1.
Useful information on metallic surfaces can be found at the Journal of Computer Graphics Techniques site.
For detailed information on the Metalness parameter, go to Chaos blog post.
Examples
Below are some examples and their settings.
width20%
width60%
Image slider
Panel
borderStylenone
Diffuse color (142, 141, 141), Reflection color (145, 142, 176), Glossiness 1
Chromium
Panel
borderStylenone
Diffuse color (244, 202, 104), Reflection color (255, 250, 195), Glossiness 1
Gold
Panel
borderStylenone
Diffuse color (227, 220, 193), Reflection color (245, 245, 237), Glossiness 1
Nickel
Move the slider to see the example renders.
width20%
