Anchor | ||||
Edge Trimming V-Ray Proxy Files
V-Ray Proxy files are often created in other software, not Maya. This may result in their axes having a different orientation than the native Maya one. Having axes with a different orientation obstructs Chaos Scatter from trimming the instances properly. This is the case for all Chaos Cosmos assets and proxies created in V-Ray for 3ds Max. You need to adjust their axes if you want to scatter such proxy files and use Edge Trimming. To do so:
Fancy Bullets | ||
Section | |||||||||||||||||||||||||
Anchor | ||||
Example: Enable Edge Trimming
Anchor | ||||
Rotation
