width55%
The V-Ray TexHairSampler is a utility node that provides extra output attributes which can be used when shading hair.
This node allows you to map color, incandescence, and transparency along the length of a hair strand, as well as the ability to randomize such properties on a per-strand basis to create stunning hair looks.
UI path: ||mat Network|| > V-Ray > Texture: Utility > V-Ray Hair Sampler
width5%
width40%
