Section | |||||||||||||||
Animation
Type – Determines whether the files are treated as an image Sequence or an Explicit animation. The Sequence Type reads the files as a whole animation , while the and offers more intuitive settings. It is ideal for general purposes. The Explicit type allows you to select a single frame from the texture animation and use it as a static shader. Parameters are different for each type. manually animate and offset the animation frames and offers more advanced settings.
