Expand
titleVRAY_GPU_PLATFORMS Exapmles...
Code Block
languagec#
VRAY_GPU_PLATFORMS=gpu // only GPU devices will be used
VRAY_GPU_PLATFORMS=titan;// Titan GPUs will be used
VRAY_GPU_PLATFORMS=intel cpu;gtx 980 // Intel CPU devices and GTX 980 devices will be used
VRAY_GPU_PLATFORMS=titan index0;titan index2 // the first and third GTX Titan graphics card installed on the machine will be used
Miscellaneous
VRAY_USD_PROVIDER– Specifies the USD plugin version. Starting with V-Ray 6.20.02, the default USD version used in V-Ray Standalone is changed from 0.22.11 to 0.23.11. The possible options for this environment variable depend on the availability in the installation vray_usd folder.
For example, VRAY_USD_PROVIDER=0.22.11.
