width50%
The Animation Rendering feature acts as a quicker animation preview, allowing you to send the scene animation for a previz sequence in Chaos Vantage.
To start rendering animation with Chaos Vantage:
width45%
Right-click the Vantage icon and select Render Animation with Chaos Vantage.
Click the image to enlarge it.
width10%
width45%
V-Ray menu > Live-Link to Chaos Vantage > Render Animation with Chaos Vantage
For more details on sending animation to Chaos Vantage for rendering, visit the Vantage page.
width5%
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/bDlTLWkqcM4" title="Elevate Previz Quality and Cut Render Times with Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Options
width55%
Initiate a Live-Link to Chaos Vantage – Initiates a Live Link session between Maya and Chaos Vantage.
Stop the Live-Link to Chaos Vantage – Stops the Live Link session.
Render Animation with Chaos Vantage – Exports and sends the current animation range to Chaos Vantage. Note that the animation considers the Time Slider's Animation Start/End options and the scene's FPS. Chaos Vantage prompts you to accept or change the animation settings, and to select a directory, where the animation is written.
Once the animation starts rendering, Maya's interface is disabled to prevent unwanted changes to the animation. To abort the animation, use the LiveLink Animation window that pops up.
Chaos Vantage Live-Link Settings – Allows you to change the Live Link port and select what happens with the live-link upon animation render end.
width5%
width40%
