In previous versions of V-Ray, you would typically need to create contours using a time consuming shader setup with the V-Ray Toon material. Now in V-Ray 5, you can simply add or remove Contours as an attribute to any shader, without any need for re-assigning materials. In addition, contours can also be assigned and controlled globally, so that you can easily apply contours to your entire scene.
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Free Trial
urlhttps://www.chaos.com/free-trial?utm_campaign=docs-tutorials&utm_medium=website&utm_source=docs.chaos.com
Align
aligncenter
HTML
<iframe width="800" height="450" src="https://www.youtube.com/embed/QvLNxVRQuko" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
