changes.mady.by.user Kristin Ivanova
Saved on Apr 16, 2024
Saved on Jun 07, 2024
The Square Size in For this example is 500 cmthe Per square option is disabled.
The Square Size in this example is 500 cm.
For this example, the Pattern is set to a rectangular Grid. Here, the offset is applied to the U V axis only (the Lock V option is disabled).
For this example, the Pattern is set to a rectangular Grid. The offset here is applied to both the U and V axes (Lock V option is enabled).
Offset = U 0; V 0
Offset = U 0; V 0.5
Image Added
Offset = U 0; V 0.75
Offset = U 0; V 1
Offset = U 0.25; V 0.25
Offset = U 0.5; V 0.5
Offset = U 0.75; V 0.75
Offset = U 1; V 1
