For this example, the Per square option is disabled.
width
45%
Example: Per Square
Anchor
PerSq
PerSq
The Square Size in For this exampleis 500 cm, the Per square option is enabled.
width
5%
width
5%
width
45%
Image slider
startIndex
1
Panel
borderStyle
none
Count = 1000
Panel
borderStyle
none
Count = 2500
Panel
borderStyle
none
Count = 10000
width
45%
Image slider
startIndex
2
Panel
borderStyle
none
Count = 1000; Per Square = Off
Panel
borderStyle
none
Count = 1000; Per Square Size = 1000
Panel
borderStyle
none
Count = 1000; Per Square Size = 4000
Panel
borderStyle
none
Count = 1; Per Square Size = 100
Panel
borderStyle
none
Count = 1; Per Square Size = 1000
width
5%
width
5%
width
45%
Example: Density
Anchor
density
density
The Square Size in this example is 500 cm. It shows how different maps create patterns of instances on the surface.
width
45%
Example: Density Texture
Anchor
Dmap
Dmap
Using a Density texture generates a brand new instance distribution. The total number of instances (approximate to the Count value) is preserved and distributed on all surfaces that correspond to map values above 0 (parts of the map not being purely black). Instances are more likely to be generated in areas with higher Density Texture values than darker ones.
