The  following light types can be created with V-Ray for Houdini:
Responsivegridmacro
Columns2repeat(2, 1fr)
Columns3width1000px
Columns1repeat(3, 1fr)
Columns1width1380px
Columnsrepeat(4, 1fr)
Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailOverlayRectangleOpacity0.45
ThumbnailBGImageCornerRadius4px
ThumbnailBGImageHeight300px250px
ThumbnailSubTextSize12px11px
ThumbnailTextColourWhite
ThumbnailTitleTextSize21px22px
ThumbnailOverlayRectangleHeightThumbnailOverlayRectangleBottomPadding50%10px
columnwidth
Sectiondiv
class
dashboard
25%
Thumbnail
ThumbnailTitleTextV-Ray Direct Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+Direct+Light
width25%
Thumbnail
ThumbnailTitleTextV-Ray Dome Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+Dome+Light
Columnwidth
25%
Thumbnail
ThumbnailTitleTextV-Ray IES Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+IES+Light
width25%
Thumbnail
ThumbnailTitleTextV-Ray Omni Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+Omni+Light
Sectioncolumn
width25%
Thumbnail
ThumbnailTitleTextV-Ray Rectangle Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+Rectangle+Light
width25%
Thumbnail
ThumbnailTitleTextV-Ray Sphere Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+Sphere+Light
Columnwidth25%
Thumbnail
ThumbnailTitleTextV-Ray Spot Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+Spot+Light
Columnwidth
25%
Thumbnail
ThumbnailTitleTextV-Ray Sun Light
ThumbnailPageLinkhttps://docs.chaos.com/display/VRAYHOUDINI/V-Ray+Sun+Light
  • V-Ray Ambient Light permeates a scene and illuminates from all angles equally without providing contrast. For more information, see V-Ray Ambient Light.
  • V-Ray Direct Lights can create light sources that cast parallel light rays in a single direction. For more information, see V-Ray Direct Light.
  • V-Ray Dome Light (also considered an area light) creates light within a dome or spherical shape to create a traditional global illumination setup. This Light is frequently used to load HDRI environment images. For more information, see V-Ray Dome Light.
  • V-Ray IES Lights (photometric lights) are designed to simulate a light source's distribution pattern sources exactly as they behave in real life by loading and using an IES (Illumination Engineering Society) file. An IES profile contains details about the light's behavior, such as how the light passes through fresnel lenses, its intensity, and falloff. For more information, see V-Ray IES Light
  • V-Ray Mesh Lights can create light sources that have volume and shape defined by geometry in the scene, without the need to use self illuminated objects and global illumination. For more information, see V-Ray Mesh Light
  • V-Ray Omni or Point Light is a V-Ray specific light that can be used to create physically accurate lights that casts rays in all directions from a single source. For more information, see V-Ray Omni Light.
  • V-Ray Rectangle Lights, also known as VRayLightRectangle or an "area light", is a planar light source with the shape of a rectangle or circular disk. Rectangle lights are useful for simulating man-made light sources in an interior environment, such as lamps. A rectangle light can have any of the two different shapes: plane or disc. For more information, see V-Ray Rectangle Light.
  • V-Ray Light Sphere is a VRay Light object in the shape of a sphere, casting light outward in all directions. For more information, see V-Ray Sphere Light
  • V-Ray Spot Light is a V-Ray specific light source plugin that can be used to create a physically accurate light that directs a narrow beam of light with falloff. For more information, see V-Ray Spot Light.
  • V-Ray Sun and Sky System: A Sun light Light (part of the V-Ray Sun and Sky system) is a spherical light source placed at a specific location which simulates the sun in the sky. For more information, see see V-Ray Sun Light.
UI Text Box
typeinfo
 A Sun light has some unique qualities:
Fancy Bullets
typecircle
  • Sun light rays that strike the scene objects are treated as parallel to one another regardless of how far the Sun object is placed from the scene objects, producing the parallel shadows that our own sun creates.
  • A Sun light is designed to be used with global illumination; when the light bounces around the scene, the resulting rendering looks very much like sunlight in real life.
  • A Sun light can work in conjunction with a Sky environment background to provide realistic lighting and coloring for the scene when used with GI. Often, Sun/Sky is the only lighting setup needed in the scene to produce a photo-real rendering.
  • The Sun/Sky combination is suitable for an exterior scene, or for an interior scene with windows or other openings through which the light comes.
width30%
width40%
width30%
Fancy Bullets
typecircle
  • V-Ray supports the v@Cd, f@intensity, and f@power parameters when instancing V-Ray lights. Note that the f@intensity is not supported for instanced IES lights.
