Button | Description | |||||
Saves currently displayed image to a selected file. | ||||||
Press and hold the "Save" icon: Save – Saves currently displayed image to a selected file. Save all – Saves each render element as a separate file using a specified file format. Save CXR – Stores all the information from the VFB (all render elements, including the LightMix, tone mapping, denoising data, etc.) inside a single CXR file. | ||||||
Sets the VFB content to the host app frame buffer. | ||||||
Copies currently displayed image into clipboard. | ||||||
Erases currently displayed image. | ||||||
Activates mode for editing the render regions. | ||||||
Disable All – Disables all selected regions. Delete all – Removes all selected regions. | ||||||
Activates pick mode for selecting objects and setting of camera focus point. | ||||||
Hides/shows tools sidebar. | ||||||
Stops the rendering process without discarding any additional data or post-rendering actions. This is the same as the "Stop rendering..." button in the Cinema 4D Picture Viewer window
Using the Cancel button (use the side arrow) stops the rendering process and discards denoising or post-rendering actions as well as skips saving output files (if were set up). | ||||||
Press and hold the Render button: Render – Starts rendering process. Start IR – Starts Interactive Rendering. Resume last – Resumes last render. Resume file – Resumes rendering based on a previously saved CXR file. | ||||||
This drop-down list allows to select the multi-pass to be displayed in the VFB. | ||||||
This drop-down list allows performing zoom actions. Lock IR resolution – This checkbox locks the image aspect ratio when the IR is running. |
Section | |||||||||||||||
Section | |||||||||||||||||||||||||||||
