In this chapter we'll cover the V-Ray textures that load and present in various ways different file formats. The BRDFs (and some lights) have many Color, AColor and Float parameter slots that can be textured. You will usually just load texture files, but V-Ray also offers many procedural textures, as well as texture plugins that serve as modifiers (i.e. apply some simple function, combine textures, extract data from one of the channels etc.). There are over 200 texture plugins, so we will only look at the most important ones. Many of the plugins are made for specific host applications. Apart from the texture data itself, V-Ray uses UVW generator plugins to generate UVW mapping coordinates or modify the original data from the geometry source. Using a UVWGen plugin is not obligatory.
TexBitmap
This texture uses the data from a bitmap buffer (see the next two points) with some additional parameters, like color multipliers, tiling etc.
Fancy Bullets
typecircle
  • compatibility_with - This is used to differentiate between textures exported from different applications. The value means : 0 - 3ds Max (this is also the default), 1 - Maya, ...
  • alpha_from_intensity - If 2 - the alpha is forced to 1.0f; 1 - the resulting alpha is the color intensity (if compatibility_with is 0) or the color luminance (if compatibility_with is 1); 0 - the alpha is taken from the bitmap alpha
  • invert - If true, the resulting texture color will be inverted
  • invert_alpha - If true and invert is on, the resulting texture alpha will be inverted too. If false, just the color will be inverted
  • color_mult - A multiplier for the texture color
  • color_offset - An additional offset for the texture color
  • alpha_mult - A multiplier for the texture alpha
  • alpha_offset - An additional offset for the texture alpha
  • nouvw_color - The color when there are no valid uvw coordinates
  • color - The resulting color
  • out_transparency - The resulting transparency
  • out_alpha - The resulting alpha
  • out_intensity - The resulting intensity
  • uvwgen - The uvw generator for the texture
  • tile - 0: not tiling; 1: tile in UV; 2: tile in U; 3: tile in V; 4: tile in UV, but not filter tiling;
  • placement_type - The way the valid portion of the texture is applied. This parameter lets you crop the texture or reduce its size for custom placement. Cropping and placement settings affect the texture only as it's used for this map and any instances of the map. They have no effect on the texture file itself. Possible values are:
    • default (0) - the whole texture is valid
    • crop (1) - Cropping a texture means reducing it to a smaller rectangular area than it originally had. Cropping doesn't change the scale of the texture.
    • place (2) - Placing a texture lets you scale the map and place it anywhere within its tile. Placing can change the texture's scale, but shows the entire texture. The four values that specify the placement and size of the cropping or placement region are all animatable.
  • u - U coordinate of the valid texture sector
  • v - V coordinate of the valid texture sector
  • w - Width of the valid texture sector
  • h - Height of the valid texture sector
  • jitter - Amount of random placement variation
  • tile_u - If true there is horizontal tiling
  • tile_v - If true there is vertical tiling
  • uv_noise_on - If true the noise is enabled.
  • uv_noise_animate - If true the noise is animated. Use "UV noise phase" to animate the noise.
  • uv_noise_amount - UV noise amount
  • uv_noise_levels - UV noise iterations
  • uv_noise_size - UV noise size
  • un_noise_phase - UV noise phase
  • bitmap - The BitmapBuffer for the texture
Examples
All following examples are rendered using the scene bundle, by uncommenting the following #include in the main .vrscene file.
The scene is "vrscenes/map_01 TexBitmap.vrscene".
Texture color-corrected using gain and lift
The scene is "vrscenes/map_02 TexBitmap corrections.vrscene".
Texture gamma-corrected using BitmapBuffer
The scene is "vrscenes/map_03 TexBitmap & BitmapBuffer gamma.vrscene".
Texture gamma-corrected using MayaGamma
The scene is "vrscenes/map_04 TexBitmap & MayaGamma.vrscene".
BitmapBuffer
This plugin loads an image file. A large number of formats are supported - lossy/lossless, from 8-bit to 32-bit. This is not a texture plugin and its only purpose is to feed data to TexBitmap. It has some options for filtering and gamma. Currently supported formats are HDR, EXR, PNG, BMP, TGA, SGI, JPG, PIC, TIF, PSD, VRIMG. Image file lists in the form of IFL files are also supported.
Fancy Bullets
typecircle
  • filter_type - -1 - nearest; 0 - no filtering; 1 - mip-map filtering; 2 - summed area table filtering; 3 - elliptical filtering; 4 - deprecated, do not use; 5 - sharp mip-map filtering
  • filter_blur - blur parameter used for filtering
  • color_space - Specifies the color space of the .hdr image so that the inverse curve can be applied to make the image in a linear color space. Possible values are:
    • linear (0) - No correction is applied.
    • gamma corrected (1) - The color space is controlled through the Gamma parameter.
    • sRGB (2) - The .hdr image is in sRGB color space.
    • auto (3) - Automatic corrections are applied.
  • gamma - A gamma–correction value for the image. For example, if the bitmap was saved to disk with a 2.2 gamma correction, you need to enter 0.4545 to remove that correction for the rendering.
  • allow_negative_colors - if false negative colors will be clamped
  • interpolation - Interpolation method for the mip-map filtering. See the example below. Possible values are:
    • bilinear (0) - Image values are interpolated from four pixels in the bitmap. This is the fastest interpolation method, but the result is not continuous (non-smooth) and may produce artifacts when the map is used for displacement or bump mapping.
    • bicubic (1) - Image values are interpolated from sixteen pixels in the bitmap. This is the slowest method, but the results are smooth without too much blur.
    • biquadratic (2) - Image values are interpolated from nine pixels in the bitmap. This method is faster than the Bicubic interpolation, but may smooth the image too much.
  • file - The file name; can contain or tags for Mari or Mudbox tiles respectively,or $nU and $nV for explicit tiles; lower-case tags consider the tiles as starting from 0 whereas upper-case tags start from 1
  • load_file - if set to false, the file would not be loaded
  • frame_sequence -frame_number -True if there are multiple files for animation with frame number in their names. Enables replacing "<frameNum>" in the given 'file' string with current frame number.
  • frame_offset -number -When working with image sequences, this parameter specifies which image out of the sequence should be used. If the parameter is omitted or defaulted (-2147483648), the frame number depends on the current frame time value.
  • frame_offset -Start frame offset for image sequences
  • use_data_window - true to use_data_window - true to use the data window information in e.g. OpenEXR files; otherwise false
  • psd_group_name -
  • psd_alpha_name -
  • ifl_start_frame - Specifies the beginning of the texture animation. The frame number specified here will be played at the first frame of the scene animation
  • ifl_playback_rate - Controls the animation speed of the texture as fraction of the actual animation speed. A value of 1 means that the texture animation will run at regular speed. A value of 2 means that the texture animation will run twice as fast as the scene animation.
  • ifl_end_condition - Image file list (IFL) end condition. This option allows you to control what happens when the last frame of the animated texture is reached. The available options are:
    • Loop (0) - The animation will start again from the frame specified in the Start Frame option
    • Ping Pong (1) - The animation will be played backwards until it reaches the the frame specified in the Start Frame option and then play forward againHold (2) - The animation will stop at the last frame and it will be displayed until the end of the scene animation.then play forward again
    • Hold (2) - The animation will stop at the last frame and it will be displayed until the end of the scene animation.
Example - Image file list (IFL) sequence
width40%
Below is an example vrscene with assets for an image file list (IFL) sequence. It can be rendered as a standard animated scene in V-Ray.
Sequence_IFL.zip
A note about the BitmapBuffer settings in the vrscene:
Fancy Bullets
typecircle
  • BitmapBuffer::frame_sequence is set to 1, which should automatically set the BitmapBuffer::frame_number from the IFL in BitmapBuffer::file
The following SettingsOutput parameters are also worth mentioning:
Fancy Bullets
typecircle
  • anim_start – Start of animation range in time units, e.g. frame_start / frames_per_second.
  • anim_end – End of animation range in time units, e.g. frame_end / frames_per_second.
  • frame_start – The frame number at the start of the animation range.
  • frames_per_second – The requested number of frames per unit time (related to SettingsUnitsInfo::seconds_scale, which should be equal to 1.0f / frames_per_second).
  • frames – List of key frames.
width60%
Image Added
Code Example for BitmapBuffer with IFL sequence
Tabs Container
directionhorizontal
Tabs Page
titlePython
Code Block
languagepy
# Compatibility with Python 2.7.
from __future__ import print_function
# The directory containing the vray shared object should be present in the PYTHONPATH environment variable.
# Try to import the vray module from VRAY_SDK/python, if it is not in PYTHONPATH
import sys, os
VRAY_SDK = os.environ.get('VRAY_SDK')
if VRAY_SDK:
    sys.path.append(os.path.join(VRAY_SDK, 'python'))
import vray
SCENE_PATH = os.path.join(os.environ.get('VRAY_SDK'), 'scenes')
# Change process working directory to SCENE_PATH in order to be able to load relative scene resources.
os.chdir(SCENE_PATH)
def onStateChanged(renderer, oldState, newState, instant):
    if oldState == vray.RENDERER_STATE_IDLE_INITIALIZED and newState == vray.RENDERER_STATE_PREPARING:
        print('Sequence started.')
    if newState == vray.RENDERER_STATE_IDLE_FRAME_DONE or newState == vray.RENDERER_STATE_IDLE_DONE:
        print('Image Ready, frame ' + str(renderer.frame) +
              ' (sequenceEnd = ' + str(renderer.sequenceEnded) + ')')
        if newState == vray.RENDERER_STATE_IDLE_FRAME_DONE:
            # If the sequence has NOT finished - continue with next frame.
            renderer.continueSequence()
        else:
            print('Sequence done. Closing renderer...')
# Create an instance of VRayRenderer with default options.
# The renderer is automatically closed after the `with` block.
with vray.VRayRenderer() as renderer:
    # Register a simple log callback. Always useful for debugging.
    def dumpMsg(renderer, message, level, instant):
        if level == vray.LOGLEVEL_ERROR:
            print("[ERROR]", message)
        elif level == vray.LOGLEVEL_WARNING:
            print("[Warning]", message)
        elif level == vray.LOGLEVEL_INFO:
            print("[info]", message)
        # Uncomment for testing, but you might want to ignore these in real code
        #else: print("[debug]", message)
    renderer.setOnLogMessage(dumpMsg)
    # Add a listener for the renderer state change event. We will use it to detect when a frame is completed and allow the next one to start.
    renderer.setOnStateChanged(onStateChanged)
    # Load scene from a file.
    renderer.load(os.path.join(SCENE_PATH, 'Sequence_ifl.vrscene'))
    # Maximum paths per pixel for interactive mode. Set a low sample level to complete rendering faster.
    # The default value is unlimited. We have to call this *after* loading the scene.
    renderer.setInteractiveSampleLevel(1)
    # Start rendering a sequence of frames (animation).
    renderer.renderSequence()
    # Wait until the entire sequence has finished rendering.
    renderer.waitForSequenceEnd()
Tabs Page
titleC++
Code Block
languagecpp
#define VRAY_RUNTIME_LOAD_PRIMARY
#include "vraysdk.hpp"
#include "vrayplugins.hpp"
#include "utils.h"
using namespace VRay;
using namespace VRay::Plugins;
using namespace std;
const char *BASE_PATH = getenv("VRAY_SDK");
string SCENE_PATH = (BASE_PATH ? string(BASE_PATH) : string(".")) + PATH_DELIMITER + "scenes";
void onStateChanged(VRayRenderer &renderer, RendererState oldState, RendererState newState, double instant, void* userData) {
	if (oldState == IDLE_INITIALIZED && newState == PREPARING) {
		printf("Sequence started.\n");
	if (newState == IDLE_FRAME_DONE || newState == IDLE_DONE) {
		printf("Image Ready, frame %d (sequenceEnded = %d)\n", renderer.getCurrentFrame(), renderer.isSequenceEnded());
		if (newState == IDLE_FRAME_DONE) {
			// If the sequence has NOT finished - continue with next frame.
			renderer.continueSequence();
		} else {
			printf("Sequence done. Closing renderer...\n");
int main() {
	// Change process working directory to SCENE_PATH in order to be able to load relative scene resources.
	changeCurrentDir(SCENE_PATH.c_str());
	// Load V-Ray SDK library.
	VRayInit init(NULL, true);
	// Create an instance of VRayRenderer with default options.
	// The renderer is automatically closed at the end of the current scope.
	VRayRenderer renderer;
	// It's recommended to always have a console log
	renderer.setOnLogMessage(logMessage);
	// Add a listener for the renderer state change event.
	// We will use it to detect when a frame is completed and allow the next one to start.
	renderer.setOnStateChanged(onStateChanged);
	// Load scene from a file.
	renderer.load("Sequence_ifl.vrscene");
	// Maximum paths per pixel for interactive mode. Set a low sample level to complete rendering faster.
	// The default value is unlimited. We have to call this *after* loading the scene.
	renderer.setInteractiveSampleLevel(1);
	// Start rendering a sequence of frames (animation).
	renderer.renderSequence();
	// Wait until the entire sequence has finished rendering.
	renderer.waitForSequenceEnd();
	return 0;
Tabs Page
titleC#.NET
Code Block
languagec#
using System;
using System.IO;
using VRay;
using VRay.Plugins;
namespace _01_animate_from_scene
	class Program
		static void Main(string[] args)
			string SCENE_PATH = Path.Combine(Environment.GetEnvironmentVariable("VRAY_SDK"), "scenes");
			Directory.SetCurrentDirectory(SCENE_PATH);
			// Create an instance of VRayRenderer with default options. The renderer is automatically closed after the `using` block.
			using (VRayRenderer renderer = new VRayRenderer())
				// Add a listener for any type of log message.
				renderer.LogMessage += new EventHandler<MessageEventArgs>((source, e) =>
					// You can remove the if for testing, but you might want to ignore Debug in real code
					if (e.LogLevel != LogLevelType.Debug)
						Console.WriteLine(String.Format("[{0}] {1}", e.LogLevel.ToString(), e.Message));
				// Add a listener for state changes.
				// It is invoked when the renderer prepares for rendering, renders, finishes or fails.
				renderer.StateChanged += new EventHandler<StateChangedEventArgs>((source, e) =>
					if (e.OldState == VRayRenderer.RendererState.IDLE_INITIALIZED
						&& e.NewState == VRayRenderer.RendererState.PREPARING)
						Console.WriteLine("Sequence started.");
					if (e.NewState == VRayRenderer.RendererState.IDLE_FRAME_DONE)
						Console.WriteLine("Image Ready, frame " + renderer.Frame +
							" (sequenceEnded = " + renderer.IsSequenceEnded + ")");
						renderer.ContinueSequence();
					if (e.NewState == VRayRenderer.RendererState.IDLE_DONE)
						Console.WriteLine("Sequence done. (sequenceEnded = " +
							renderer.IsSequenceEnded + ") Closing renderer...");
				renderer.Load("Sequence_ifl.vrscene");
				renderer.SetInteractiveSampleLevel(1);
				renderer.RenderSequence();
				renderer.WaitForSequenceEnd();
Tabs Page
titleNode.js
Code Block
languagejs
var path = require('path');
var vray = require(path.join(process.env.VRAY_SDK, 'node', 'vray'));
var SCENE_PATH = path.join(process.env.VRAY_SDK, 'scenes');
process.chdir(SCENE_PATH);
var renderer = vray.VRayRenderer();
// It's recommended to always have a console log callback
renderer.on("logMessage", function(message, level, instant) {
	if (level == vray.LOGLEVEL_ERROR)
		console.log("[ERROR] ", message);
	else if (level == vray.LOGLEVEL_WARNING)
		console.log("[Warning] ", message);
	else if (level == vray.LOGLEVEL_INFO)
		console.log("[info] ", message);
	// Uncomment for testing, but you might want to ignore these in real code
	//else console.log("[debug] ", message);
renderer.on("stateChanged", function(oldState, newState, instant) {
	if (newState == "idleFrameDone" || newState == "idleDone") {
		console.log("Image Ready, frame " + renderer.frame +
			" (sequenceEnd = " + renderer.sequenceEnded + ")");
		// Check if the sequence has finished rendering.
		if (newState == "idleDone") {
			// Closes the renderer.
			// This call is mandatory in order to free up the event loop.
			// The renderer object is unusable after closing since its resources
			// are freed. It should be released for garbage collection.
			renderer.close(() => {});
		} else {
	} else if (newState.startsWith("idle")) {
		console.log("Unexpected end of render sequence: ", newState);
		renderer.close();
// Load scene from a file asynchronously.
renderer.load("Sequence_ifl.vrscene", function(err) {
	if (err) throw err;
	// Prevent garbage collection and exiting nodejs until the renderer is closed.
	renderer.keepAlive();
Example - The Interpolation Parameter
This example shows the effect of the different interpolation methods. The images below show a teapot displaced with this texture:
Notice how the different interpolation methods produce slightly different results with different smoothness.
Code Example for TexBitmap and BitmapBuffer
Tabs Container
directionhorizontal
Tabs Page
titlePython
Code Block
languagepy
firstline1
renderer.load(os.path.join(SCENE_PATH, 'material.vrscene'))
# Create a bitmap buffer which can load data from a file
newBitmap = renderer.classes.BitmapBuffer()
newBitmap.file = os.path.join('assets', 'bricks01.jpg')
# TexBitmap is used for file-based texturing. Other Tex{*} plugins offer procedural and combination textures
newTexture = renderer.classes.TexBitmap()
# Set the texture to use the loaded buffer
newTexture.bitmap = newBitmap
brdf = renderer.classes.BRDFDiffuse()
# Attach the texture as input to the brdf.
brdf.color_tex = newTexture
newMaterial = renderer.classes.MtlSingleBRDF()
newMaterial.brdf = brdf
newNode = renderer.classes.Node()
newNode.material = newMaterial
newNode.geometry = renderer.plugins['CubeShape@mesh2']
newNode.transform = vray.Transform(vray.Matrix(1), vray.Vector(-15, 0, 0))
Tabs Page
titleC++
Code Block
languagecpp
firstline1
renderer.load("material.vrscene");
// Create a bitmap buffer which can load data from a file
BitmapBuffer newBitmap = renderer.newPlugin<BitmapBuffer>();
newBitmap.set_file("assets" PATH_DELIMITER "bricks01.jpg");
// TexBitmap is used for file-based texturing. Other Tex{*} plugins offer procedural and combination textures
TexBitmap newTexture = renderer.newPlugin<TexBitmap>();
// Set the texture to use the loaded buffer
newTexture.set_bitmap(newBitmap);
BRDFDiffuse brdf = renderer.newPlugin<BRDFDiffuse>();
// Attach the texture as input to the brdf
brdf.set_color_tex(newTexture);
MtlSingleBRDF newMaterial = renderer.newPlugin<MtlSingleBRDF>();
newMaterial.set_brdf(brdf);
Node newNode = renderer.newPlugin<Node>();
newNode.set_material(newMaterial);
newNode.set_geometry(renderer.getPlugin("CubeShape@mesh2"));
newNode.set_transform(Transform(Matrix(1), Vector(-15, 0, 0)));
Tabs Page
titleC# .NET
Code Block
languagec#
firstline1
renderer.Load("material.vrscene");
BitmapBuffer newBitmap = renderer.NewPlugin<BitmapBuffer>();
newBitmap.File = Path.Combine("assets", "bricks01.jpg");
TexBitmap newTexture = renderer.NewPlugin<TexBitmap>();
newTexture.Bitmap = newBitmap;
BRDFDiffuse brdf = renderer.NewPlugin<BRDFDiffuse>();
// Attach the texture as input to the brdf.
brdf.ColorTex = newTexture;
MtlSingleBRDF newMaterial = renderer.NewPlugin<MtlSingleBRDF>();
newMaterial.Brdf = brdf;
Node newNode = renderer.NewPlugin<Node>();
newNode.Material = newMaterial;
newNode.Geometry = renderer.GetPlugin("CubeShape@mesh2");
newNode.Transform = new Transform(new Matrix(1), new Vector(-15, 0, 0));
Tabs Page
titleNode.js
Code Block
languagejs
firstline1
// Load scene from a file synchronously.
renderer.loadSync("material.vrscene");
var newBitmap = renderer.classes.BitmapBuffer();
newBitmap.file = path.join("assets", "bricks01.jpg");
var newTexture = renderer.classes.TexBitmap();
newTexture.bitmap = newBitmap;
var brdf = renderer.classes.BRDFDiffuse();
brdf.color_tex = newTexture;
var newMaterial = renderer.classes.MtlSingleBRDF();
newMaterial.brdf = brdf;
var newNode = renderer.classes.Node();
newNode.material = newMaterial;
newNode.geometry = renderer.plugins["CubeShape@mesh2"];
newNode.transform = vray.Transform(vray.Matrix(1), vray.Vector(-15, 0, 0));
Texture loaded from a PTex file. This doesn't use BitmapBuffer. PTex is a mapping system that applies a separate texture to each face of a subdivision or polygon mesh and therefore requires no UV assignment. A PTex file can store an arbitrary number of textures along with mipmaps and adjacency data used for filtering across face boundaries. For more information on the PTex concept, see the Notes section below.
Fancy Bullets
typecircle
  • ptex_file - The Ptex texture file
  • use_image_sequence -
  • image_number -
  • image_offset -
  • ifl_start_frame - The following 3 parameters are the same as in BitmapBuffer
  • filter_type - Type of filter used for the texture
  • width - width parameter used for filtering
  • blur - blur parameter used for filtering
  • sharpness - This option is only available when the Filter Type is set to Bicubic and controls the amount of sharpening applied by the filter.
  • lerp - Interpolation between mipmap levels. A ptex texture may have several mipmap levels which are basically versions of the texture at different resolutions. This allows a higher resolution texture to be applied to parts of the object closer to the camera and a lower resolution version to be applied to parts of the object that are far away. When this option is enabled V-Ray will interpolate between different mipmap levels to create a smooth seamless texture in the end.
  • anisotropic_filtering - Enables anisotropic filtering which improves the rendering of textures when viewed at sharp angles.
  • reverse_vertices - Reverses the order of vertices. A ptex is generated for a specific mesh. Sometimes the program generating the ptex numbers the vertices of the mesh in the reverse order. When this happens the object is not properly textured and enabling this option fixes the issue.
  • cache_size - The information in a PTex file is compressed for storage. In order to be used, it has to be uncompressed and stored in the RAM. This parameter controls how much memory (in MB) is available for the current texture. If the value is large enough for the whole texture, the information is extracted only once and is stored during the entire rendering. Otherwise the information is constantly read from the hard drive, extracted, and used when necessary. Low value for this parameter may cause large PTex files to render slowly.
  • auto_color - Use automatic color channel selection. A ptex may have an arbitrary number of channels and there is no sure way to determine which channel contains which information. When this option is enabled V-Ray tries to select the correct channel for Red, Green and Blue. When this option is off the user manually specifies which channel contains which information.
  • r_channel - The index of the channel which will be used as a red channel.
  • g_channel - The index of the channel which will be used as a green channel.
  • b_channel - The index of the channel which will be used as a blue channel.
  • auto_alpha - Use automatic alpha channel selection.
  • a_channel - The index of the channel which will be used as a alpha channel.
  • alpha_type - Where to take the alpha from.
  • color_space - 0 - linear, 1 - gamma corrected, 2 - sRGB
  • color - The final texture color
  • color_gain - A multiplier for the texture color
Fancy Bullets
typecircle
  • More information about PTex is available here
  • PTex files are strongly connected to the topology of an objects's mesh. Therefore any modifiers which change the topology (including TurboSmooth and MeshSmooth) will break the rendering of the PTex texture. If you want to smooth the object, you can use the Displacement Modifier | GeomDisplacedMesh modifier with Subdivision Type and 0.0 for Displacement amount.
  • When using PTex textures for displacement, small cracks might appear along polygon edges because of slightly different filtering applied to the PTex texture on adjacent polygons. Setting the filter width to 0.0 will improve the situation, but will cause the most detailed mip-map level of the PTex file to be loaded thus increasing the required memory.
  • When using PTex textures for displacement, it might be necessary to adjust the min_bound and max_bound parameters of the GeomDisplacedMesh modifier, especially if the texture has negative colors. Otherwise the texture values might be clipped away.
