This page provides information about the Hair material in V-Ray for.
Section | |||||||||||||||||
UI Paths
||V-Ray Asset Editor|| > Materials (right-click) > Hair
Section | |||||||||||||||||||||
Diffuse
Primary Specular
Secondary Specular
Transmission
Anchor | ||||
Example: Transmission Glossiness Length and Width Parameters
Section | |||||||||||||||||||||||||||||||||||||||
Options
Anchor | ||||
Example: Opaque for GI
This example shows how important GI is for the appearance of hair, especially bright hair. GI is brute force and light cache has retrace.
Multipliers
Binding
Override Control
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Settings.
Attributes
The attributes from the following expandable menus are available for the
Hair material.
Expand | ||
Raytrace Properties |
Visible to Reflections – When enabled, this option makes objects using this material visible for to Reflection rays.
Visible to Refractions – When enabled, this option makes objects using this material visible for the Refraction rays.
Column | ||
Column | ||
Expand | ||
Material ID |
Column | |||||
ID Number – Isolates objects as an R/G/B mask in the MultiMatte render elements. ID Color – Allows you to specify a color to represent this material in the Material ID VFB render element.
Column | ||
width | 35% |
