This page provides information about the Live Link tools in Rhino and Grasshopper.
The Start a Vantage live session tool helps you send your Rhino scene to Chaos Vantage with a click of a button. Any changes you make in the scene are sent instantly to Vantage without the need to reexport the scene.
The V-Ray Live Link component offersan analogous tool to the Start a Vantage live session and is available in V-Ray for Grasshopper. While this component is running, it interactively shares the input V-Ray scene on the specified port with Chaos Vantage.
The Configures and starts a Vantage live session tool sets specific settings for performance.
Installation
The installation of the tools comes with the installation of V-Ray 5 for Rhino, update 2 and later.
For detailed instructions on installing and setting up Live Link from Rhino and Grasshopper to Chaos Vantage, see the Live Link from Rhino tutorial.
UI Path
Section | |||||||||||||||
Usage in Rhino
To start the tool in Rhino, just click the Start a Vantage live session button. This initializes a Live Link session between Rhino and Chaos Vantage.
The tool automatically:
- Starts Chaos Vantage if it is not already running;
- Sends the scene to Chaos Vantage on 20701 port;
UI Text Box | ||
Always make sure you are using the same port in both Rhino and Chaos Vantage! |
To stop the tool, click again the Start a Vantage live session button.
Learn more on the Live Link from Rhino page.
Usage in Grasshopper
Live Link Supported Features
The following changes made in the V-Ray compatible DCC are propagated through Live Link:
Fancy Bullets | ||
Excerpt |
Responsivegridmacro | ||||||||
Known Limitations
Div | |||||||||||||||||||||
UI Text Box | ||
When the Live Link session is closed, the scene is still loaded inside Vantage but it is considered dirty and the aforementioned limitations are still in effect. A .vrscene file from the host application needs to be exported and loaded inside Chaos Vantage to enable full manipulation, editing and playback. |
type | tip |
-include | ||||||
