This page provides detailed information on OSL support with V-Ray.
OSL shaders describe the appearance of a surface using symbolic representations called closures instead of explicitly computing color values. V-Ray supports some of the closures introduced by the OSL specification. Additionally V-Ray customizes the usage of OSL closure functions by defining keyword arguments. These arguments reveal additional parameters to better configure V-Ray BRDFs working behind the scenes of the OSL closures. Currently there are several guidelines and limitations to writing an OSL shader in V-Ray. Please read the Guidelines section for specifics before writing OSL shaders in V-Ray. See the Examples section for some samples.
Anchor | ||||
VRayOSLTex on the other hand ignores closure color output parameters. Writing to the built-in Ci for example is redundant. Use only simple color or float output parameters for texture shaders. All output parameters are considered as optional texture rgb output while all output float and int parameters are considered as optional texture alpha output.
Texture shader example:
Code Block |
shader simple_color_tex ( color tex_color = color(0.2, 0.45, 0.9), float tex_alpha = 1.0, output color result = color(0.0, 0.0, 0.0), output float alpha = 1.0 ) { result = tex_color; alpha = tex_alpha; } |
Material shader example:
Code Block |
surface diffuse_material ( color diffuse_color = color(0.2, 0.45, 0.9), color transparency_color = color(0.0, 0.0, 0.0) ) { Ci = (1.0 - transparency_color) * diffuse_color * diffuse(N) + transparency_color * transparent(); } |
Code Block |
string filter = "box" [[ string widget = "string" ]], |
The default UI control type for integer parameters in 3ds Max is a spinner. If your integer parameter is intended to be a boolean switch use the "widget" parameter metadata.
Code Block |
int trace_reflection = 0 [[ string widget = "checkBox" ]], |
Supported OSL Closures
Out of the many closure functions that OSL specifies VRay supports the following:
closure color vray_hair(normal N, color diffuse_color, color transparency, color primary_specular_color, float primary_glossiness, float secondary_glossiness, color transmission_color, float transmission_glossiness_length, float transmission_glossiness_width);
Closure that is primarily designed for rendering hair and fur. See VRayHairMtl for in depth parameter explanation and examples. An OSL shader that simulates the VRayHairMtl is available in the Examples section. This shader also demonstrates how the VRayHairMtl's parameters translate to the vray_hair closure ones.
Additional Closure Arguments
closure color diffuse (normal N);
float roughness;
Keyword usage example:
Code Block |
Ci = diffuse_color * diffuse(N, "roughness", 0.5); |
color secondary_specular_color;
int opaque_for_shadows;
int opaque_for_gi;
int simplify_for_gi;
int use_cached_gi;
float light_multiplier;
vector hair_direction;
Additional argument information:
If provided, overrides the internally derived hair strand direction. Default value is vector(0.0, 0.0, 1.0).
Unsupported OSL Features
Displacement and volume shaders are not supported.
Renderer state, message passing and dictionary lookups are currently not supported.
Shader Graphs
OSL shaders can be organized into networks of shaders (sometimes called a shader group, graph, or DAG), with named outputs of some nodes being connected to named inputs of other nodes within the network. Furthermore, the individual nodes are evaluated lazily, only their outputs are ”pulled” from the later nodes that depend on them.
Anchor | ||||
Examples
Example: Mandelbrot Texture
This example generates a simple Mandelbrot set using texture coordinates.
Section | ||||||||||
Shader source code:
File: mandelbrot.osl
Code Block |
shader mandelbrot ( color background_color = color(1.0), color fractal_color = color(0.0), int max_iterations = 40, output color result = fractal_color ) { float x0 = (u * 3.5) - 2.5; float y0 = (v * 2.0) - 1.0; float x = 0.0; float y = 0.0; int iteration = 0; while ((x * x + y * y < 2.0 * 2.0) && (iteration < max_iterations)) { float xtemp = x * x - y * y + x0; y = 2.0 * x * y + y0; x = xtemp; iteration = iteration + 1; } if (x * x + y * y >= 2.0 * 2.0) { result = background_color; } } |
Example: Glass
This example presents a glass material.
Shader source code:
File: vray_glass.osl
Code Block |
surface vray_glass ( float eta = 1.44 ) { Ci = reflection(N, eta) + refraction(N, eta, "auto", 1); } |
Example: Plastic
This example demonstrates a plastic material.
Shader source code:
File: plastic.osl
Code Block |
surface plastic ( color white = 1, color black = 0, float size = 0.5, float diffuse_weight = 0.8, float specular_weight = 0.16, color specular_color = 1, float exponent = 80.0 ) { float uPosition = (mod(abs(u), size) / size); float vPosition = (mod(abs(v), size) / size); color checkerValue = mix(black, white, ((uPosition < 0.5) == (vPosition < 0.5)) ? 1.0 : 0.0); closure color diffuse_component = diffuse_weight * checkerValue * diffuse(N); closure color specular_component = specular_weight * specular_color * phong(N, exponent, "trace_reflections", 1); Ci = diffuse_component + specular_component; } |
Example: Carbon Fiber
This shader implements a carbon fiber surface.
Shader source code:
File: carbon.osl
Code Block |
normal getBumpedNormal(color centerColor, color uColor, color vColor, float bumpAmount) { vector worldTangent = normalize(dPdu); vector worldBitangent = normalize(dPdv); vector worldNormal = normalize(N); vector average = vector(0.3333333); float center = dot(average, vector(centerColor)); float ddu = center - dot(average, vector(uColor)); float ddv = center - dot(average, vector(vColor)); float inverseBumpAmount = 1.0 / bumpAmount; return normalize(ddu * worldTangent + ddv * worldBitangent + inverseBumpAmount * worldNormal); } surface carbon [[ string description = "Carbon fiber material" ]] ( string diffuse_texture = "diffuse.png", string specular_texture = "spec.png", string aniso_texture = "aniso.png", string bump_texture = "bump.png", float diffuse_weight = 0.5, float specular_weight = 0.2, float specular_glossiness = 0.75, float bump_amount = 1.0, float delta = 0.004 ) { color diffuseColor = texture(diffuse_texture, u, v); color specularColor = texture(specular_texture, u, v); vector average = vector(0.3333333); color anisoColor = texture(aniso_texture, u, v); float anisotropy = 2.0 * dot(average, vector(anisoColor)) - 1.0; color center = texture(bump_texture, u, v); color uColor = texture(bump_texture, u + delta, v); color vColor = texture(bump_texture, u, v + delta); normal bumpNormal = getBumpedNormal(center, uColor, vColor, bump_amount); Ci = diffuse_weight * diffuseColor * diffuse(bumpNormal) + specular_weight * specularColor * ward(bumpNormal, dPdu, specular_glossiness, specular_glossiness, "anisotropy", anisotropy); } |
Example: Car Paint
This shader simulates car paint material.
Shader source code:
File: car_paint.osl
Code Block |
surface car_paint [[ string description = "Car paint material" ]] ( color baseColor1 = color(0.08, 0.08, 0.77), color baseColor2 = color(0.46, 0.46, 0.82), color specularColor = color(0.87, 0.87, 1.0), float diffuseWeight = 0.6, float specularWeight = 0.3, float specularGlossiness = 0.5, float reflectionWeight = 0.4, float baseFalloffAmount = 0.4, float flakeSpread = 0.6 ) { float cosNI = dot(N, -I); float baseBlendFactor = pow(cosNI, 1.0 / baseFalloffAmount); color diffuseColor = mix(baseColor1, baseColor2, baseBlendFactor); color reflectionColor = color(reflectionWeight * (1.0 - cosNI)); normal n = hashnoise(u, v) * 2.0 - 1.0; float cosFlake = dot(n, -I); if(cosFlake < 0.0) { cosFlake = -cosFlake; n = -n; } n = normalize(N + flakeSpread * n); Ci = diffuseWeight * diffuseColor * diffuse(N) + specularWeight * specularColor * vray_blinn(n, specularGlossiness, 0.0, 0.0) + reflectionColor * reflection(N); } |
Anchor | ||||
This shader demonstrates how to use the vray_hair closure.
Shader source code:
File: vray_hair_material.osl
Code Block |
surface vray_hair_material [[ string description = "V-Ray Hair Material" ]] ( // General parameters color overall_multiplier = color(0.9), color opacity = color(1.0), // Diffuse color diffuse_color = color(0.0), float diffuse_amount = 1.0, // Primary specular color primary_specular_color = color(0.05), float primary_specular_amount = 0.25, float primary_glossiness = 0.9, // Secondary specular int lock_to_transmission = 1 [[ string widget = "checkBox" ]], color secondary_specular_color = color(0.36, 0.3, 0.15), float secondary_specular_amount = 1.0, float secondary_glossiness = 0.8, // Transmission color transmission_color = color(0.6, 0.55, 0.4), float transmission_amount = 1.0, float transmission_glossiness_length = 0.95, float transmission_glossiness_width = 0.85, // Options int opaque_for_shadows = 0 [[ string widget = "checkBox" ]], int opaque_for_gi = 0 [[ string widget = "checkBox" ]], int simplify_for_gi = 1 [[ string widget = "checkBox" ]], int use_cached_gi = 1 [[ string widget = "checkBox" ]], // Advanced float light_multiplier = 1.0 ) { color transparency_color = clamp(1.0 - opacity, 0.0, 1.0); if (lock_to_transmission) { Ci = overall_multiplier * vray_hair( N, diffuse_amount * diffuse_color, transparency_color, primary_specular_amount * primary_specular_color, primary_glossiness, secondary_glossiness, transmission_amount * transmission_color, transmission_glossiness_length, transmission_glossiness_width, "opaque_for_shadows", opaque_for_shadows, "opaque_for_gi", opaque_for_gi, "simplify_for_gi", simplify_for_gi, "use_cached_gi", use_cached_gi, "light_multiplier", light_multiplier ); } else { Ci = overall_multiplier * vray_hair( N, diffuse_amount * diffuse_color, transparency_color, primary_specular_amount * primary_specular_color, primary_glossiness, secondary_glossiness, transmission_amount * transmission_color, transmission_glossiness_length, transmission_glossiness_width, "secondary_specular_color", secondary_specular_amount * secondary_specular_color, "opaque_for_shadows", opaque_for_shadows, "opaque_for_gi", opaque_for_gi, "simplify_for_gi", simplify_for_gi, "use_cached_gi", use_cached_gi, "light_multiplier", light_multiplier ); } } |
Fancy Bullets | ||
