Steps
Follow the steps below:
Step 1: Download Cosmos assets
Div
classsectionColumnWrapper
To find and download a Cosmos material asset:
  • Navigate to the Materials category in the Chaos Cosmos browser and find your desired assets.
  • Hover over an asset and click the Download (Vantage_Cosmos_blueButton.png) button.
    or
  • Alternatively, click the asset to preview it first, and then click the Download button.
    The downloaded assets are marked with the Vantage_Cosmos_Downloaded.png symbol.
To see all downloaded assets, go to the top dropdown menu of the browser and select the Downloaded category.
You can also mark any asset as your favorite from the Vantage_Cosmos_Liked.png button. To see all your favorites, go to the top dropdown menu of the browser and select the Likes category.
Div
classUIImage
Align
aligncenter
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/E95U1Qz3F7A" title="Download and Preview Chaos Cosmos Assets in Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Step 2: Apply Cosmos assets
Div
To preview how a Chaos Cosmos material asset looks on an object in the scene without assigning it:
  • drag the material asset onto an object. Note that you should not drop the asset onto the object.
To apply a Chaos Cosmos material asset on a scene object:
  • select the object and drag and drop the asset onto it.
UI Text Box
typetip
Dragging a Cosmos material asset into the viewport adds the asset to the Material Lister in Vantage.
UI Text Box
typeinfo
Note that the Import Vantage_Cosmos_greenButton.png button does not apply the material to an object. It only adds the Cosmos material to the Material Lister.
If your geometry does not have UVs, enable the Use triplanar mapping option of the Cosmos material for automatic UV mapping. Otherwise, the texture UVs will depend on the UVs of the geometry.
To replace a material with a Chaos Cosmos material:
  • dragthe Cosmos one and drop it onto the selected object.
To replace a material across the scene:
  • hold Alt and drop the Cosmos material asset onto any geometry with the original material assigned.
Div
classUIImage
Align
aligncenter
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/I8_DAIM0rp8?list=PLm2Irfq-UvZ3h2Sxw2FVd9qjOIpqHOLiG" title="Shading scenes with Chaos Cosmos material assets in Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Step 3: Modify Cosmos assets
After importing a Cosmos asset to your scene, you can change the asset’s materials. To do it, drag and drop any downloaded material from the Cosmos browser or the Material Lister onto the asset.
