This page offers a quick starting point on working with image-based lighting, sunlight, and Cosmos HDRIs in Chaos Vantage.
Responsivegridmacro
VAlignmentstart
Columns3width1000px
Gap40px
Columnsrepeat(2, 1fr)
ClassRespParagraphSide
Columns2width1200px
HideElements
cssselector#tocVertical, #tocHorizontal
CSS Stylesheet
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size {
    vertical-align: text-bottom;
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
UI Button
colorblue
newWindowtrue
icondownload
titleDownload Free Trial
urlhttps://www.chaos.com/free-trial?utm_campaign=docs-tutorials&utm_medium=website&utm_source=docs.chaos.com
Steps
Div
classRespParagraphSide
You can enhance your scene in Chaos Vantage by adding Cosmos HDRIs, as well as by using geo-located time of day settings, and advanced lighting setups. Here you can explore how to integrate high-quality HDRIs from the Chaos Cosmos library to create realistic environment lighting, adjust the time of day based on specific geographical locations for accurate sunlight simulation, and manage multiple light sources within your scene.
UI Text Box
typeinfo
Note that the final animation in the video has undergone some post-processing.
Div
Align
alignright
HTML
<iframe width="560" height="350" src="https://www.youtube.com/embed/DiDf8AZjG68" title="Image-based lighting, Sunlight, and Cosmos HDRIs in Chaos Vantage" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Steps
Load a scene or project in Chaos Vantage.
Step 1: Chaos Cosmos HDRIs Import
Open the built-in Cosmos browser by clicking the Chaos Cosmos Browser (
Vantage_TopToobar_ChaosCosmosBrowser.pngImage Removed
Vantage_TopToobar_ChaosCosmosBrowser.pngImage Added) button in the top toolbar. Alternatively, go to the Cosmos menu and select Chaos Cosmos Browser.
From the HDRI section, choose a sky image. Note that previously downloaded assets can be filtered using the Downloadedcategory.
Then import the HDRI by either:
Fancy Bullets
typecircle
  • drag-n-dropping it in the sky
  • using the import (ChaosCosmos_ImportBtn.pngImage Modified) button
Swap different HDRIs to explore different lighting scenarios.
Adjust exposure as needed.
Step 2: Time of Day Variations
In the Environment tab > Sky rollout, switch the Environment mode to Physical sky.
UI Text Box
typenote
Switching the Environment mode to Physical sky ignores the previously imported HDRI. Instead a Sky texture is used.
In the Environment tab > Sun rollout, select a Sun position mode:
Fancy Bullets
typecircle
  • switch the Sun position dropdown to Altitude/Azimuth to easily control its position in the sky by adjusting the Altitude and Azimuth parameters.
  • switch the Sun position dropdown to Geolocation to get accurate sun position based on Latitude/Longitude coordinates and Time values.
Step 3: Work with many lights
Lights can be selected either in the viewport with the Select (
Vantage_TopToobar_Select.PNGImage Removed
Vantage_TopToobar_Select.PNGImage Added) tool or in the Objects tab. Shown parameters for lights can be folded or expanded by using the Expand all lights or Collapse all lights buttons above the light lister.
Instanced lights are shown as groups marked with [G] in the light lister of the Lights tab and share settings. Making changes to one parameter changes it for all of the lights. Instanced lights can also become unique (ungrouped) by using the checkbox or the Ungroup (Image Modified) button.
Step 4: Individual control of lights
To make a change to a light, select it either in the viewport or in the Objects tab and change its parameters. Available parameters can be displayed by switching between the Compact, Basic, and Advanced buttons.
UI Text Box
typetip
You can disable the lights' gizmos via the Open View filters (Image Modified) option in the top toolbar.
Div
Align
alignright
HTML
UI Text Box
typeinfo
