Focal plane in camera view – Makes the camera focal plane visible in camera view.
Targetdistance– Defines the distance from the camera to the target.
IconSize– The size of the camera origin icon in the viewport, relative to the default size (1.0).
Show cone:
Always – Always shows the camera cone. Never – Never shows the camera cone. Whenselected –Shows the camera cone only when camere is seleceted.
width
5%
width
40%
Image RemovedImage Added
Overrides
width
55%
Use Camera scene environment – Controls the override of the global illumination from the camera. When Enabled, the color/map below this control will be used as override. When Disabled, the override will be disabled.
UI Text Box
type
note
Use Camera scene environment override is available starting from Corona 12.
Direct Override – Controls override of the environment map visible directly from the camera. Reflect Override – Controls override of the environment map visible in reflections. Refract Override – Controls override of the environment map visible in refractions.
