By default, the plgparams.exe can be found in C:\Program Files\Chaos Group\V-Ray\3ds Max 20xxMax 20xx\bin\ for V-Ray for 3ds Max 2021 and earlier, or in C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax 20xxVRay3dsMax20xx\bin for V-Ray for 3ds Max 2022 and later.
This command tells plgparams where to find your plugins. By default, the default plugins folder location is:
C:\Program Files\Chaos Group\V-Ray\3ds Max 20xx\bin\pluginsfor V-Ray for 3ds Max 2021 and earlier, or
Code Block | ||
## Example for 3ds Max 2021 and earlier "C:\Program Files\Chaos Group\V-Ray\3ds Max 20182021\bin\plgparams.exe" -plugindir "C:\Program Files\Chaos Group\V-Ray\3ds Max 20182021\bin\plugins" ## Example for 3ds Max 2022 and later "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2023VRay3dsMax2022\bin\plgparams.exe" -plugindir "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20xxVRay3dsMax2022\bin\plugins" |
To see the list of plugin names in this folder, use the following command:
Code Block | ||
## Usage plgparams -plugindir <plugin folder> -list ## Example for 3ds Max 2021 and earlier "C:\Program Files\Chaos Group\V-Ray\3ds Max 20182021\bin\plgparams.exe" -plugindir "C:\Program Files\Chaos Group\V-Ray\3ds Max 20182021\bin\plugins" -list ## Example foe 3ds Max 2022 and later "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2023VRay3dsMax2022\bin\plgparams.exe" -plugindir "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20xxVRay3dsMax2022\bin\plugins" -lilst |
Note that the plugin folder must be specified with the -plugindir switch each time you run the command.
Code Block | ||
## Usage plgparams -plugindir <plugin folder> <plugin name> ## Example for 3ds Max 2021 and earlier "C:\Program Files\Chaos Group\V-Ray\3ds Max 20182021\bin\plgparams.exe" -plugindir "C:\Program Files\Chaos Group\V-Ray\3ds Max 20182021\bin\plugins" BRDFGlass ## Example foe 3ds Max 2022 and later "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax2023VRay3dsMax2022\bin\plgparams.exe" -plugindir "C:\ProgramData\Autodesk\ApplicationPlugins\VRay3dsMax20xxVRay3dsMax2022\bin\plugins" BRDFGlass |
This will list all the parameters for the plugin , and definitions for each.
Section | |||||||||||||||||||||||||
